Results 1 to 16 of 16
Thread: 10 bolt 8.5 posi
- Jul 2006
- Clinton, MS
- 184
10 bolt 8.5 posi
I need a new posi unit, I am in the market because the old carrier is cracked and the clutches are worn out. Im thinking about an Eaton clutch type or Detroit Locker or the Detroit Truetrac. Which one is mostly used out there?
01-30-2007 #2Eaton clutch type is like a factory unit......so they would be the most common type. Great posi for a frequently drive car.
-Carm'69 Firebird Twin Turbo SBC 400" Blow-through
9.80 @ 141 w/ 1.88 60-ft..... on 17's
9.21 @ 153 w/ 1.45 60-ft..... on PUMP GAS
8.60 @ 164 w/ 1.46 60-ft..... on RACE GAS
01-30-2007 #3Depends on what you want to do with the car. If it will be a street/strip car then the Eaton is probably the best. If it will be drag raced a lot then the Detroit Locker would be better. If it will be taking curves fast then the Truetrac is better. What do you want it to do?
'69 RS/SS396 pro street/427/4spd/9"
http://rides.webshots.com/album/576443881hfGXxd
http://good-times.webshots.com/album/568860081GZRpyZ
01-31-2007 #4
- Jul 2006
- Clinton, MS
- 184
No drag strip use, Mostly street and a few SCCA events
01-31-2007 #5
- Nov 2004
- 444
