Results 1 to 9 of 9
Thread: Help with brake system
03-20-2007 #1
Ok guys, despite my best efforts to find the answers I need in previous discussions, I have been unable to do so. I've never bent or flared a brake line in my life so I'm kindof a dummy when it comes to engineering a brake system. Sorry in advance for the length...
My 69 Camaro has factory power front discs with stainless brake hoses and factory lines, which I think I will be able to retain. Now...I recently put a 9" rear from a Lincoln Versailles and retained the disk brakes from that car with all new rotors, pads, calipers, etc. Also, I had new stainless brake hoses made up to run from the calipers to the rear hard lines. Oh, and I already have the proportioning valve to splice into the front-to-rear line.
So the questions are:
A) Do you guys think my 1 1/8" bore factory master cylinder will get the job done, or if not, which MC do you think would work. Is there any reason I should be looking at 7/8"? wilwood?
B) Does the factory distribution block just below the master cylinder need to be removed from the system?
C) I'm thinking I will buy a front-to-rear line from inline tube (with the wilwood proportioning valve spliced in), and then fabricate by own rear axle lines, does this seem appropriate or is there a better or easier way?
Even with the drum brakes, this car really stopped quite well for a street car, so I'm not looking to do the hydroboost at this juncture (car has manual steering so would be opening a whole new can of worms on that one). The money really isn't a huge issue here, so if it's a whole new power booster and MC that I need, so be it. I just want to get it right and have the car stop as well or better than it did before.
Thanks guys!
Jeff K.
69 Camaro SS, 406 SBC, TKO600, 9" w/3.73 tru-trac, Speedtech Arms, AFX Spindles, Lee 670 Box, Baer GT front, C5Z rear. Hyperco Leafs w/ Fays2 Watts Link + Varishocks.
