      cheap solution for sand blaster
      I'm in need of a sand blaster for the garage. Nothing major as I can't imagine myself using it often. I would like to sandblast a few small parts and maybe one quarter and a valence. what would I need for a cheap solution?
      VA
      harbor freight sells some small ones, i have one. It works OK. I'd like a better one though b/c i like blasting the undersides of a car. Dunno where to look for one that wont have the same problem
      Feb 2007
      Be sure you have the right resperator. Don't want to breath that stuff in and get silicoses.
      Feb 2007
      Plano
      i bought a pressurized kettle blaster for less than $100 on sale at Northern tool. Bought play sand at home depot and strained it with window screen, worked great for $5.00 for a 50lb bag!
      Jun 2006
      southern connecticut
      mhotel1, that's a great idea, never thought of using regular play sand...i bought a 10 gallon sandblaster from northern last summer, never got to use it yet, would play sand be a little to hard on sheet metal?
      what size compressor are you guys running them on? think a 30 gallon craftsman 120 volt would be too small?
      May 2000
      If you're just going to do a few parts, and have a place outside to do it. Heck, you can get a hand held blaster at Wal-Mart for like $15 bucks. It's a siphone feed, just put on end in the bag of sand. Works greats. I've used it a couple times, and use fine white sand. Larger sand will not work.
      Lees Summit, Missouri
      Quote Originally Posted by MarkM66
      Agreed, for small parts, this type works just fine.
      Later - Craig
      [email protected]
      '70 Chevelle (in storage now, probably will never be back on its wheels again!)
