Thread: Opinions on brake set up
03-19-2007 #1
I'm looking to build this car on the cheap, so i dont have like $5000 to spend on front and rear big brake kits. let me know what you think about what im planning. Also i wanna be able to fit behind my stock snowflakes. cars a 79 T/A.
stock calipers from parts store - $?
SSBC front stock size slotted rotors with hi po pads - $200
SSBC rear caliper/rotor/pad kit (does all back end) - $700
SSBC adj. prop valve with dist block - $120
Stock brake hoses front/rear from parts store(does anyone make SS thats what i'd really like to firm it up) - $?
Power brake services hydroboost system 6" booster and master cylinder - $550
please let me know, like i said im just planning things right now. thanx in advance.
1979 Trans Am - In the big junkyard in the sky
1980 Turbo Trans Am - In the big junkyard in the sky
A journey of a thousand miles begins with a single BURNOUT!
03-19-2007 #2I'd look more at getting soem 12" B body spindles and disc on the front. I think the slotted won't give you a noticable inprovement. They allow you to keep the stock calipers.
Also unless you really liek the look of the hydroboost, my 79-81 small 4 wheel disc dual diaphragm booster stil works with 12" of vacuum and lower with other motors. A bunch of money you could spend other places in the brakes.
Earls and Russel make SS flex lines, not real expensive through Jegs or Summit.
