    Results 1 to 20 of 28
      May 2002
      Southeastern WI
      Carbon Fiber hood from Year One
      I got the hood for my Camaro on Friday. I was a little disappointed to see they (manufacturer Glasstek) had blasted it with a heavy coat of black primer. I guess I was expecting to see the weave under the surface.
      It definitely is lighter than the Harwood fiberglass one I took off.
      I sanded the primer today, but was not able to finish. This is where I need opinions. It will be a lot of work to sand all the primer off and clearcoat it for the natural CF look. Should I just straighten it out (there are some low spots) and paint it?
      Jeff
      Atlanta GA
      that sucks.. but hey at least its light!
      hows the fitment?
      May 2002
      Southeastern WI
      Fits great without the hinges on. A little high in the left rear corner. The right side hinge is sloppy so I ordered a new GM set from Rick's. I did have to remove a little material from the sides where the rubber bumper is on the fenders. The hood is too deep on the sides.
      Jeff
      Central CA USA
      Can you weigh it for me?
      Atlanta GA
      Snohomish, Washington
      Quote Originally Posted by Venomous Type
      or you can get this...WHOA, big cowl!
      http://cgi.ebay.com/ebaymotors/67-68...QQcmdZViewItem
      haha that is kinda cool.
      Matt
      Aug 2003
      the Ebay ZL1 hood in the link is a fiberglass hood with a Carbon fiber overlay.
      As for the Year One CF hood, if the hood was not laid up with a clear gel coat, it is not goint to give you the natural look you are looking for. Sounds like they used a black gel coat.
      May 2002
      Southeastern WI
      David, it weighs 19 lb. The Harwood 4" cowl hood weighs 25 lb with the latch assy still attached. Not that much lighter I guess..
      Jeff
      Aug 2003
      It looks like the Year One hood has a fiberglass frame.
      Mountain View, CA
      I'm guessing that Glasstek does not use a UV compatible resin.
      True T.
      My blog
      IL
      I put a Glastek CF hood on a friends 69 camaro a couple of years ago and it had a fiberglass frame and it was not finished with clears resins, only black gel coat. In his case it is a 10'5 inch tire car so he was looking for the weight savings not the look. I want one like Charlie got for Red Witch. Now that is a nice looking hood!
      Rick
      May 2002
      Southeastern WI
      Thanks for the input guys. I think it will be easiest just to primer it or put a flat clear on it until I decide to paint the car. Otherwise I will spend a lot of time trying to match the crappy paint on the car.
      Jeff
      Mountain View, CA
      I'd love to find a CF hood in the stock/flat configuration (and decklid too!). I don't really want a Cowl Induction hood, but if that turns out to be the only way to go I s'pose I'll have to.
      True T.
      My blog
      May 2002
      Southeastern WI
      I was happy to dump the 4" cowl hood and get back to a 2". I have a stock SS hood but my carb would be sticking through it.
      Jeff
      Aug 2003
      Damn, we are making a mold for the deck lid now. We are doing Lisa's Empty nest in blue carbon fiber. No plans for a flat hood though.
      May 2002
      Southeastern WI
      I would consider a flat deck lid as well, depending on cost.
      Jeff
      Mountain View, CA
      Quote Originally Posted by ProdigyCustoms
      Make a second one in black that'll fit a '68 Camaro and it's sold.
      Can I send you my stock flat hood to make a copy of?
      True T.
      My blog
      Aug 2003
      Quote Originally Posted by Damn True
      The mold cost would be prohibitive unless there are a lot of other buyers, but the deck lid I see selling.
      Jul 2001
      Calgary, AB
      I would be in for a deck lid. What kind of timing are you looking at Frank?
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
      IL
      I be in for a deck lid depending on price! Any idea on how much you are thinking Frank?? I know the more pepole in helps justify the cost of doing this kind of stuff.
      Rick
