      Melbourne, FL
      1st gen F-body accelerator pedal mount???
      I have a 67 'Bird that I am installing the 68-69 style pedal that uses a cable instead of a rod. Will a 67 Camaro bracket fit the 68-69 style that originally came with a plastic mount. My original 67 metal mount doesn't fit the swivel rod. But I noticed that the 67 Camaro metal bracket has a different number that the Firebird. But the Camaro/Firebird share the same bracket for 68-69.
      So can I order a 67 Camaro bracket to use on my 67 'Bird ???
      67 Firebird Convert 455 +.060 Johnny Winters TH400 74cc KRE d-port flowed @ 310 cfm heads piston dished 16cc H-beam rods Comp Cam 305-AH-8 cam 108* LSA 253/260 @.050 duration .577/.594 lift w/1.65 rockers Ford 9" 3.55 Detroit Locker M/T Sportsman Radials 31x18x15 on Convo Pro 15x15s
      Honest dad that 455 on the side of the block is a serial number
      Kettering, OH
      I believe the bracket is plastic for the cable pedal. The' 67 six cylinder cars has a cable throttle so it should work.
