    Results 1 to 11 of 11
      La La Land, CA
      Supercar style parking brake?
      Guys-
      We are in the process of installing a rear disc brake kit onto a 69 Camaro that does not have a parking brake provision due to the caliper design. We have found a cool solution that can be retrofitted to most any car now that we distibute for Brembo.
      I wanted to see if any one had interest in this style of caliper as an add-on to their current rear disc brake system. The caliper is a non hydraulic floating pull style caliper, and can be seen on the McLearen F1, Carrera GT, and the Enzo Ferrari. If there is some interest, we will make a full kit to go with most rear end types and disc diameters.
      Tyler
      Jul 2003
      allen, texas
      how much?
      Feb 2006
      Boulder, Colorado
      Cool. Can we see more pics of the back? How does it mount?
      Eric
      69 Camaro - LT1 w/ 700R4, DSE springs, swaybar and Konis. Still rockin' it old school with 15" wheels and 60 series tires.
      California
      Honestly, I've never been a fan of that kind of parking brake, but I suppose if it's the only way to use one, I'd live with it.
      Matt
      Jul 2001
      Calgary, AB
      Will it work with the AP's?
      James
      1967 Camaro RS - The OLC
      1984 Camaro GT1
      1989 Camaro 1LE - The BOC
      Feb 2003
      Sacramento, CA
      its a good idea. would be eaiser then tryin to fab up ebrake cables. guess it all depends on cost for a kit........
      1972 Camaro LS6
      Mantorville, MN
      What, you couldn't just shove a stick in the drilled rotor holes? :D
      Texas
      Looks sweet. It's down low too.
      Most 2 piston and all 4 piston calipers don't have an integral parking brake. They are performance calipers and require a 2ndary safety system.
      I think the add-on unit is the best solution, but that depends on the $$$$ for the kit.
      How are the costs compared to willwood "spot" calipers?
      Jun 2006
      Indianapolis,IN
      I have seen the street rod crowd put a disc on the rearend and use a third brake caliper like the one in the pic. Not sure how the disc attaches? looks like its on the pinion, Best I remember.
      Tim
      Northwestern NJ
      Quote Originally Posted by PRRC
      Tim
      That's a grerat way to go on a car with IRS. It helps keep the unsprung weight down.
      Tommy
      Tommy Souren
      "The older I get, the faster I was."
      Grandma's 20k mile '80 Malibu Classic, in-progress factory style LS6 454, Legend LGT 700 5 speed, 9" 3.70 posi, Global West suspension, 12"/11" discs.
