Results 1 to 20 of 23
Thread: Voltgage problem
02-14-2007 #1
- Oct 2004
- 50
Voltgage problem
I have a 68 camaro and i bought the ron davis radiator with the duel fan setup on it. I have a 140 amp alternator and i rewired the car with the painless wireing kit. When ever my fans turn on my volts drop from 14 to 11.5 when in gear. When its idleing in park you can hear a change in rpm, it drops. My alternator is from kragon auto parts, so i dont know the amps at idle. If anyone has any clue it would help.
02-14-2007 #2how many wire alternator is it? i think the 1 wire ones dont work until reved up, heres a link
http://www.madelectrical.com/electri...hreewire.shtml69 camaro, 383 stroker, 700r, 3:73 auburn, JL stereo, marquez lights front/back, adj qa1's, custom dash, sts swaybars 1 1/4-7/8, global west a-arms/subframe connectors, suede interior.
http://hobbystage.net/camaro/jigga99/
02-14-2007 #3
- Oct 2004
- 50
Sorry that i did not put that it is a one wire. I found out that it is 80amps at idle.
02-14-2007 #4Did your alternator come with a bench test data sheet. I know some companies are including them with their alternators. If no sheet was included just remember that just because it's rated at 80amps at idle you may not necessarily be getting that on the car. Also, how much draw is on the system (stereo, AC etc.)
Good luck,
-MikeMike M
67 Camaro, big plans, empty wallet!!
02-14-2007 #5
- Jun 2006
- Indianapolis,IN
- 1,605
A lot of street rods have this same problem. There are some companys that make a 1 wie that charges at idle.I will look and see if I can find you a name of the company.
Tim
02-14-2007 #6
- Oct 2004
- 50
No it did not come with the bench sheet. I called kragens and they called the maker and thats what they said. Im only running a crane hi-6 box and the electic fans on top of the normal electonics in the car. Tim thank you very much for looking for me.
Josh
02-15-2007 #7
