    Results 1 to 18 of 18
      Oct 2006
      roll cage benders...
      tubing shark, is it any good?
      what's a relatively cheap solution that will do both rollcages and exhaust?
      Greenville, IL
      I don't know that there is a good bender to do both roll cages and exhaust on one machine. Most of your cage benders have a min. wall thickness that is rather thick for exhaust. On the same level, most exhaust benders have a max. wall thickness less than min. cage thickness.
      This is just what I know of the machines I have looked at. If there is a machine that can do both, I would like to know it also.
      Also the exhaust benders tend to neck down the material about 10 to 15 %.
      Oct 2006
      ahh
      so what about just the tubing shark for the cage work?
      Jan 2007
      the difference is that the cage bender needs to be of a manderal format and bend the tube in a different method than an exhaust bender. This is so that it does not weaken the tube in the bend area. I have never seen a machine that can do both that is under 50,000.
      for a cage bender look at medfordtools.com and thier model 3. Its great for the self fabricator.
      Jason
      Jan 2007
      Quote Originally Posted by absolom
      ahh
      its ok, but i find that because it bends up it can create some problems when doing mainhoops and other multiple complex compound bends.
      model 3 and a digital level will work wonders with some practice.
      Jason
      Oct 2006
      Quote Originally Posted by jason@gmachine
      Jason
      thanks, looks like good stuff, and the price is nice too
      Merritt Island,FL
      JD Squared makes a good economical bender.
      Makes very nice bends.
      Check out my web site.
      Missouri
      I have been doing some research on tubing benders and wanted to share. I also didn't think there should be another thread so I'm adding to this one.
      You can buy the plans here http://www.gottrikes.com/Tube_Bender.htm this is the one I'm going to build and I will be doing the air over hydrolic version. Here is a whole lot of information on it http://www.pirate4x4.com/forum/showthread.php?t=376183
      This one makes the most sense for me considering that it doesn't take a lot of floor space to bend tube, it bends it vertical.
      Here are some others I have found.
      http://blindchickenracing.com/Tools/...bingbender.htm
      http://www.metalwebnews.com/howto/tu...be-bender.html
      http://www.rorty-design.com/content/...nder_plans.htm
      http://www.pro-tools.com/ there are free plans from them. I also have the pdf if anyone wants it.
      I will post up pictures as soon as I start this project.
      Sean James
      69 Firebird - Build Thread
      72 Firebird
      VA
      Quote Originally Posted by 67speedfreak View Post
      Thats the one I use.. I'm not very good at it tho.. Works good and has done a bunch of cages so far.
      Maryland
      I've used exhaust benders on roll bar tubing for years and it does a pretty fair job,as long as you don't go past 90 degrees{for some reason it gets all stupid and starts to flatten the tubing past 90}I now have a JD2 model 4 with a hydraulic/air cylinder.It was about $2000,but it works really well and will bend to 180 degrees.The thing I didn't like about the tube shark is that it was verticle instead of horizontal,it seems like it would be hard to lay another peice of tubing on top of it to copy a previous bend,but I'm sure there is a way,and you'd get used to it.Ron
      Feb 2009
      Manitowoc Wisconsin
      There are many simple manual benders on the market for the "garage" builders out there. Just google tube benders.
      I just converted mine to pneumatic/hydraulic, good bender for the money invested. Now if only I had a DRO of the angles and could set the bender for spring back and other nice features lol
      Quote Originally Posted by Damn True View Post
      Occupant comfort and the eardrums of the neighbors kids are secondary concerns.
      Feb 2009
      Manitowoc Wisconsin
      Quote Originally Posted by Otto-813 View Post
      Need an NC bender
      san diego
      speedway motor has a cheap bender
      Jun 2011
      I use a hossfeld number two bender. It does a great job.
      Oct 2010
      SLC
      I have the pro-tools bender and have been very happy with it so far. they gave me a decent deal on a bender, and notcher. I think they are a sponsor for the dezertrangers forum, so they frequently run specials on that site. Also I have found their customer service to be fantastic.
      Zach
