Thread: What first?
02-08-2007 #1
What first?
Hello all:
I want to improve the handling of my '75 Firebird and want to know which order to do modifications. In other words, which mod will show the greatest improvement, and then the next greatest improvement, etc. Assuming you are starting with a car with no mods, what order would you do?
Lower profile/better performing tires
subframe connectors/solid body bushings
performance shocks
g-braces
solid or del-a-lum control arm bushings
aftermarket upper control arms
what else??
Thanks, Rick
02-08-2007 #2
- Aug 2004
- Pittsburgh, PA
- 316
Hey Rick,
The first thing that should be done is to give the existing components a good inspection. Go through the steering, suspension joints and check for slop & wear.
IF you find they need replaced that is the place to start. If you get it all torn apart you might as well use the good stuff if you can afford it. You might as well do the springs & shocks since you have it apart. After that wheels/tires are easy enough, along with the body mounts & SFCs. You can then bolt on the arms & additional chassis bracing.
If the stock stuff is good:
body mounts & SFC, chassis braces
wheels/tires
bushings, springs, shocks, arms
I went through my suspension twice, before I figured it out. Depending on your starting point it varies a little. I almost forgot the what else...
You are probably going to want to inspect the power steering system. Along with the suspension work, now would also be a good time to plan/consider future mods such as brakes, rear end work, tranny swap etc. If you plan ahead you dont have to do stuff over & over.
Shane
02-09-2007 #3
Full Blown G-Machiner
- Sep 2004
- PA.
- 935
