    Results 1 to 20 of 25
      Southern NJ
      Reinforcing stock front LCAs.
      Has anyone done any extra bracing or boxing on their front lower control arms? I'm going to do a new set for my GTO to go with my pro-lites, and I was thinking about reinforcing them a bit. Thoughts?
      Matt
      1965 Pontiac GTO – Spotts 421 Tripower | TKO600 | 3.90s | Vintage AC | Baers | Hotchkis/SPC/BMR Suspension | Intro Vistas | BFG KDW Redlines | 06 GTO Seats
      little falls minnesota
      Cut and fit a piece of 10ga. or 11ga. to fit inside the bottom of the arm.
      Using one piece would be best, then stitch it every 1-2". It'll add some weight ,but it will help.
      Doug
      May 2002
      Northern California
      this was with 1/8" mild steel.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Dec 2003
      lost
      1/8" steel sheet
      Marshall , MO
      http://www.einstyn.com/einstyn-hardtop-05.htm
      Contact Pete he has them pre cut.
      Brad Shepard
      69 Malibu
      Marshall, MO
      Jan 2007
      Quote Originally Posted by MrQuick
      i like how this is done, but personally i would use 4130 and throw some dimple dies in it, then TIg it into the arm. Although this is much stranger than stock too!
      Jason
      Southern NJ
      Thanks guys - those pics were exactly what I was thinking about doing, and it's nice to know I wouldn't be the first.
      Matt
      Mantorville, MN
      Quote Originally Posted by sinned
      1/8" steel sheet
      This is exactly how I would do it too, most important is the strap around the balljoint, as these arms are notorious for cracking there, the other piece takes care of where most of the flex occurs in these arms.
      Southern NJ
      I am the farthest thing from an expert on the subject, but wouldn't this compound the problem of weakness around the ball joint area, by creating stress focus point at the end of the reinforcements??
      Compare the above to this pic: http://www.einstyn.com/einstyn1/itsbroke3.jpg
      Matt
      PA.
      Here`s a pic of a set I did some years back. The plate was .095" if I remember right. We finished them up with machined steel ball joint inserts pressed and welded into the arms that took our PC Series ball joints set up with screw in housings and GM taper pins. No worries about cracking with that setup. I boxed the bushing end too as the arms deflect pretty easily in that area. Mark SC&C
      Mantorville, MN
      Those look heavy...
      Dec 2003
      lost
      I also weld all the outer bushing shells into the arms to effectively box all the pivot areas (another weak link in GM arms).
      PA.
      They may "look" heavy but they`re not. Remember it`s .095". If memory serves the stock arms weighed 14 1/2 lbs. Boxed they weighed about 16 1/2lbs. A total of 4lbs. on a 3800lb. car....
      I`ve weighed tubular lower arms that were "lighter than stock" that weighed 18+lbs. One G body lower arm was 22lbs.! Guess they figured nobody would actually weigh them. FWIW the tubular A body lowers we`re working on right now are 12 1/2lbs. Mark SC&C
      Eastern Virginia
      Marcus, Do you have lower tubular G body A arms? Or which ones do you recommend?
      EDIT: Nevermind, I see them on your website.
      Scot
      86 Monte SS
      Red Deer, Alberta, Canada
      Quote Originally Posted by Marcus SC&C
      I take it they are not finished? No hole from the sway bar, or bump stops. That is if your running both of what i said. haha
      heres a pic of mine before powder coating.
      -Matt
      Matt
      Instagram: Cst_koon
      PA.
      Right you are. Bumpstops thread into welded threaded inserts. The swaybar mounts were fabricated and adj. for rate.
      Nice job on yours BTW! Mark SC&C
      Southern NJ
      1/8" steel sheet
      FYI, I just installed my reinforced LCAs done almost exactly as above. I was very disappointed to find that the ball joint strap makes pretty good contact with my front discs. I've been grinding them down for hours, and I'm about to just cut them off. I've groud almost all the way through them as it is. What a waste of time!
      Matt
      To me your post kind of comes off as its Dennis' fault?
      Either way mine is not even close to touchy the rotor. Are you sure everything is right on your setup?
      Matt
      Instagram: Cst_koon
      Southern NJ
      Quote Originally Posted by protour_chevelle
      Sorry - wasn't bashing Dennis. If anything I'm disappointed with the $55 kit from einstyn.com (which is identical to the pieces Dennis showed in his photos). For $55, I got two $1 straps for the balljoints (which I'm cutting off), and a pair of rusty reinforcements with no countours that look like they were cut out of a piece of scrap by a 3-year-old. I spent hours trying to make them work and the result may have been functional, but it sure isn't pretty.
      The contact with the rotor at the ball joint strap may be exaggerated by another problem - my alignment isn't dead-on yet - but I still think the straps have to go.
      On top of that, my SC&C pro-lites are making hard contact with my brake lines on both sides at less than full travel. I have no idea what to do about that problem. And my braided lines are binding on the LCAs at less than full turn, and I have no idea what to do about that either.
      To sum up - I'm beginning to wish I had left my stock control arms with poly bushings in place.
      Matt
      PA.
      Matt, that`s a little strange ours have a lot more clearance there than most fixed tubular arms. It`s no biggie though,just bend the lines out of the way. You may need to move a clamp and redrill the hole. Sounds like your brake hoses are too short though. Mark SC&C
