    Results 1 to 20 of 23
      Houston, Tx
      Rear LS1 Swap - BRP Brackets - Need help
      Hi,
      I purchased the rear LS1 conversion brackets from BRP and I am having some trouble finding out what parts I need for the swap -
      I have a 1969 Camaro with staggered shocks. I have heard that you need two left setups for it to work.
      I have been searching for days and I have not been able to find an exact list of part numbers or anyone who has documented the steps it takes for the installation.
      Also, does anyone know how long my new studs should be for the new brakes to work?
      Chris
      May 2002
      Northern California
      Yes, you need 2 lefts to work with stag's.
      Wheel studs, I recommend metric type, Dorman #610-323 or Napa 641-1581
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Chris,
      Take a look at my old website: www.geocities.com/diels12000
      I've got the part numbers there.
      Joe
      Nov 2004
      Pickering,Canada
      do you still need 2 lefts if your car is mini tubbed???
      May 2002
      Northern California
      depends on shock location. you can redrill the plates to rotate them up out of the way if you really needed to. heres another alternative...
      Old Joe? does this mean you are making a new one??
      Houston, Tx
      Thanks for all of the information.
      BRP Sells a relocation kit that puts both shocks in from of the axle. Does anyone have an opinion on that kit?
      I think the cost is right at $150
      Kettering, OH
      What do you do for parking brake cables if you keep the original pedal and intermediate cable setup?
      Houston, Tx
      Quote Originally Posted by Hammered
      I am pretty sure that the ls1 cables work if you run the L&R calipers and brackets.
      Quote Originally Posted by MrQuick
      Nope, you can't out engineer The General. They've already performed the homework and I just want to pass along the part numbers. Unlike some companies out there
      Joe
      May 2002
      Northern California
      Hey Taylor,
      yes those would work perfectly,
      Hammered, you can use the stock LS1 rear cables and brackets, you just have to modify the frame brackets to relocate them closer to the front.
      No, your web site Joe....LOL silly are you doing a new web site?
      Kettering, OH
      I have a '67 so I can run a L & R and have the cables pull from the front. The bottom of my car is already detailed so cutting and welding is a very last resort. I wonder if I can get Inline Tube or someone to make a ******* cable to fit?
      May 2002
      Northern California
      F****** Lokar dude. They can set you up. Just make bolt on brackets to secure the cables.
      May 2000
      Why metric?
      May 2000
      Would someone please post a link to BRP? Thanks
      Houston, Tx
      Quote Originally Posted by MarkM66
      Why metric?
      Metric is actually perfect in my case - I have ATS spindles and they have metric studs.
      Houston, Tx
      http://www.brphotrods.com
      Phil (the owner) I actually a really nice guy. I am not sure why BRP doesn't get more discussion on here.
      Dublin, CA
      part number and studs
      You probably already got the part number for the left hand brackets, but just in case: 10444626
      As for metric wheel studs... I could not find the knurl I wanted in 12mm for the fronts, so went with 1/2-20s instead. But the rears require no drilling to tap out for using 1/2-20 screw in studs. Just another option.
      Brent
      Yep, www.engineeredvelocity.com
      Remember I asked you if I could use some of your pics!
      Joe
      May 2002
      Northern California
      cool, yes i did. Sweet stuff and great prices but one suggestion? Can you change the color of the prices?
      My eyes almost poped out of my head... and not just because of the great prices. vin
      Houston, Tx
      Thanks for the replies everyone. I think that I'll be doing the BRP shock relocation and regular L&R setup and adding some new longer studs to my axles. BRP will weld the parking break cable bracket to the lower shock mount and the setup is supposed to work really well.
      I plan on taking pictures of the whole process because this stuff doesn't seem to be very well documented anywhere.
