    Results 1 to 10 of 10
      hydroboost problems
      guys i need some help;
      i just installed my hydroboost system. the unit is from abs power brake,
      the problem that i am having is that when we attempted to bleed the rear right caliper the fluid would not come out with pressure. this is after about twenty minutes of trying. then we tried it with the car on and we got the same low pressure, and also the lines that run from the hydro to the power steering pump would get hot (is it suppost to?)
      please help me
      vince
      Jun 2006
      Long Island
      Hot lines
      I was just on Htdratech's website and they do say that it is normall for the lines to get hot during operation as for the line pressure problem i don not know how to help. May be you might have a clog in the line on a kink in the line.
      Metro Detroit
      I had the same problem. Wrong master cylinder.
      R.P.
      wrong master cylinder meaning one that is for a disc drum?
      Metro Detroit
      call me at 248.624.4526
      R.P.
      Indiana
      Is there a chance you have the line from the p/s pump to the hb and the line from the hb to the steering gear reversed?
      I did that to the one on my Blazer and after looking at my El Camino a few times I finally realized I had the lines backward! I swapped them and voila, I had brakes!
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      rp i will call tomorrow in the morning so that i am able to look at the car.
      thanks vince
      Newbury Park, CA
      Car on/off will have no effect on being able to bleed the system. It can and should be bled with the engine off.
      The power steering feed/return lines will get warm if the engine is running.
      Did you bench bleed the master cylinder?
      I agree with the above. Either the wrong/bad/incorrectly bled master cylinder.
      i did find out about the maser and it is one for a disc set up. since this weekend we had no success as soon as i have the chance i will bleed the system all over again. i will start from the master and then go to the furtherst most to nearest the master, wish me luck
      vince
      Metro Detroit
      Quote Originally Posted by vince72
      Vince, I bought my master cylinder from Baer. It was what they sold me. It still did not work. I had the same bleeding problems. I talked to Paul at Hydratech, switched MC and 10 minutes later all is good.
      Hydratech is listed as a supplier here. 586.427.6970
      Great guy. Very knowledgeable.
      R.P.
