    Results 1 to 20 of 31
      Nov 2004
      Eastern Washington
      My VW Title Issue
      For anyone who was interested, after 6 LOOONGGG months, I finally got a title in the mail yesterday!!!
      Finally this is resolved....sort of. Ohio titles need a notary, but this is from Missouri and no notarization has taken place. I hope they are not required from there. I will have to hurt someone...
      Figures too. I went and put a retainer on a lawyer yesterday too. They were going to try and get me an Ohio title.
      Jun 2005
      The Moon
      If notary isn't required in the state it's coming from then you shouldn't need it to be here in Ohio. My Mustang had a CA title with no notary and I had no problem getting it transfered.
      -Jim...
      1970 Mustang Mach 1, Global West tubulars, roller bearing everything, del-a-lums, 355 Windsor Tremec TKO 600, lots more on the way
      A few other cool toys too
      Jul 2003
      Anaheim Hills, CA
      You inspired part my my current "don't get robbed" story. Glad you finally got a title.. at least it's a step.
      1968 Track Rat Camaro:
      The Netherlands
      Country Flag: Netherlands
      We have a WINNER!!!! cool your efforts finally paid off...
      Martin
      1st 2nd
      Pro-Touring outside the USA !
      Martin's Camaro Page
      Apr 2002
      What about the states that don't have titles, only registration? if your state has titles, will the car now have one?
      --JMarsa
      Nov 2004
      Eastern Washington
      I wasnt aware that other states did not have titles. Louisianna didnt require titles until about 15 years ago, but Ohio would require one to register the car in this state. They will not even allow titles from companies like 'Broadway Title'. If you dont have one in Ohio, you are SOL. You can get a lawyer who can get you one if you can provide proof you purchased it in good faith. The lawyer will perform a VIN search to make sure it is not stolen and then present your case to the courts.
      congrats, now hopefully we can both have some luck with the idiots that screwed us over!
      330 H.O. gm crate, edelbrock carb/intake, headman headers,T-56 6 speed, mcleod clutch, hurst shifter looking for a home.
      1969 Camaro- under eternal restoration
      NY
      Cool deal! When are you getting your air ride and bad brakes??
      The needs of the many outweigh the needs of the few.
      Nov 2004
      Eastern Washington
      LOL eventually. I want to get it cleaned up and running for now.
      My plans are for a 4 valve air ride kit, 5" narrowed front beam, BAD brakes with dropped CP spindles 17x7 rims and a 2270cc type 4 motor.
      It'll look a little like this when done (without the rag clip):
      NY
      The '54 I'm redoing is getting pretty much the same treatment. The PITA is it's a link pin front with a swing axle rear, and since the stuff he sells is for a '57-up, there's alot of modifications I have to do to get the stuff to work. Nothing too bad, and at least I'm getting paid to do this car.
      Nov 2004
      Eastern Washington
      Quote Originally Posted by toxicz28
      I love oval windows.
      The link and swing shouldnt make a difference. All Bugs from 1949 - 1968 had a swing axle rear. From 49 - 65 they all had a link front and the pan didnt really change between that time. If you mean Pete at Airkewld, he sells a kit that is for 49-65 Bugs. It should work on your 54. I'd love to see some progress pics. Keep up the good work restoring a great car
      http://www.airkewld.com/parts/prodde...?prod=ARK-4100
      NY
      Quote Originally Posted by JoshStratton
      Yeah, that's whose kit I'm using. The 4 valve kit is nice.
      The bulkheads for the shock mounts were off, had to get new ones. The original park brake was adjusted at the front beam, new cables only go to the handle, gotta cut the tunnel to cut the cable tubes and bend them so they hit the handle. Park brake handle opening is .543" new park brake is .901". The best is, after all the crap I went through to get the bulkheads, when he (the guy I'm doing the car for) went to order his transmission, he found out he had a crashbox that's only good for about 40hp( ) he needed to get an entirely different transmission, so the axle tubes, bulkheads, brackets, etc. that I refinished for him are now useless. It's just little tedious B.S. and setbacks. The time schedule was blown away. It was supposed to be going back to him (the owner) rolling, with the body painted and polished this weekend. The pan doesn't even roll yet . I'll stop complaining now. Once I get the pan rolling, I'll post up some pics for you.
      Feb 2006
      SoCal
      Hey Josh!
      I think I saw your car out here in Cali! Did you go to the Pomona Swap Meet a few months back?
      Nice Car BTW! I used to have a '68 with a 2 liter and some 48's. No one used airbags to lower their bugs in those days so I pulled some shims out of the front beam, relocated the spring plates in back and dropped her that way! It dropped so low that I had to put skateboard truck and wheels on the front of the car to make it over speed bumps!
      John
      ***Under Construction***
      Build Update Link:
      Nov 2004
      Eastern Washington
      At least his is a lot farther than mine will be in the next few years :(. I hope to just get it running and add parts as I go. The bulk of my time/cash will be going into my Trans Am. I wanted something to drive until the TA is road worthy.
      Nov 2004
      Eastern Washington
      Quote Originally Posted by novanutcase
      Hey Josh!
      John
      Skateboard wheels. That is the first I have heard of that. It's a pretty good idea! I bet that was a hard ride. That's the only thing I dont like about old Bugs, every pot hole sounds like a car crash. Well, that and the low seats. I like the way they look, but getting hit from the rear will brake your neck.
      I have never been to Pomona, unfortunately. This car was found in Missouri. From what I know, it's been there the last 26 years, sitting in a field and then later a gravel lot. It isnt pretty inside (and smells like pee) but the body is pretty decent and should be a cheap-ish restoration.
      EDIT: It just occured to me that you meant the car in that picture I posted. That is what mine will look like, sorta, eventually. That car belongs to Pete who owns www.airkewld.com.
      This is my car (not very pretty): http://www.joshuastratton.com/CarStu...ug/index2.html
      Feb 2006
      SoCal
      Oh yeah! BIG difference!! What'cha got planned for the motor?
      Build Update Link:
      Feb 2006
      SoCal
      Yeah...bugs aren't known for their "stellar" suspensions.........
      Build Update Link:
      Nov 2004
      Eastern Washington
      You almost need a tetinus shot from looking at it.
      I would like to put in a 2270cc Type4 motor. My goal is a very reliable 150 HP @ 30+mpg
      Feb 2006
      SoCal
      RELIABLE??? On 2 liters?? Good Luck! Unless they have made these size motors more reliable, I can tell you that you will be wrenching on this sucker pretty much every weekend! I would imagine that you will top it off with some Weber 48 IDA's? Those things are a bear to adjust but when you do....LOOKOUT...that motor will scream!!! Make sure you run a stout trans as the VW stock ones will blow up with that kind of power. I went through 2 transmissions before coughing up the dough and buying a bus tranny. Make sure you use blued axles too. I sheared the ones on my first tranny.
      John
      Build Update Link:
      NY
      The '54 I'm doing, only had a little bit of rust. It's biggest problem it had was cracks in the metal.
      Make sure your trans isn't a crashbox. The easiest way to tell, is if the case splits down the middle giving you a right and a left half. They're garbage and won't handle more than 40hp. (per the owner of strictly foreign)
