01-23-2007 #1
Removing Parking brake cable from FW
I give up, what is the trick to getting the parking brake cable detached from that goofy connector at the floorpan/firewall.
I unscrewed the 'cap' on the firewall side of things and I've removed the parking brake mechanism.
How is this thing attached?
01-24-2007 #2I used a cut-off wheel, But I was replacing it anyway. You could try a small hose clamp to get the tabs in enough to get it through the firewall, then remove the clamp.
The needs of the many outweigh the needs of the few.
01-24-2007 #3I tried the clamp action. No luck.
Ya know what, it's a friggin 37 yr old part. I'll just cut it off and get a new one.
Safety first! (and I get to use the cut-off wheel! woot!)
01-24-2007 #4
