Results 1 to 15 of 15
Thread: complete suspension, 71 camaro
01-14-2007 #1
- Jan 2006
- 9
looking for advice/input/commentary/discussion on suspension plans for my 71 camaro.
first, about the car. it's a work in progress (aren't they all), but these are the components that the suspension will be accomodating:
71 camaro
aluminum-headed 406 smallblock, flywheel HP ~ 450
T56 6spd manual
9" rear w/ 3.90 or 4.00 gears, truetrac or trak-loc
16x8 wheel, 4.5" BS, toyo RA1 255/50/16 all the way around
my goals so far include:
1) keep weight in check. hollow sway bars, aluminum center for the 9" rear, etc., where possible/practical
2) balance of street, strip, and track manners. No 90/10 shocks, no 900 lb/in coils, no slapper bars/caltracs. If I can cut a 2.0 or better 60ft, get above 0.9g on the skidpad, and keep the ride nice enough to keep all my teeth in my head after a 2 hour cruise, I'll be happy.
For frame of reference:
* My 1991 Z28's FE2 (stiffer IROC-rate springs/swaybars) suspension is definitely too soft, I want something more "sporty" than this
* my 2002 miata (with factory suspension package including stiffer springs and bilstein shocks) is more of what i'm looking for
3) avoid the use of solid bushings in the rear end (I presently have solid aluminum bushings in the front spring eyes, and they transmit an obnoxious amount of gear noise to the car)
4) maintain a near stock ride height with no rake (i.e., flat) for multiple reasons - front tire clearance in the wheelwells, header clearance, etc. etc.
So, what I think I'm looking for is:
1) rear leafs in the 170-185lb/in range, stock or near stock ride height, with some kind of anti-axle-wrap design (most of the leafs towards the front, double-front eye, etc.) Herb Adams front perch modification (re-drilled holes 3/4" higher in perch). Preferrably rubber bushings, metal to metal bushings as a last resort. How quiet can the lined bushings (i.e. del-a-lum types) be?
2) front coils in the 450-500lb/in range, with stock or near stock ride height. More (+) caster, (-) Caster around 0.75*. Tubular arms if they offer a weight savings or geometry improvement. SC&C street-comp stage 2 stuff?
3) Good shocks all the way around (bilstein or koni, potentially QA1 or others but I'm not familiar with their stuff much).
input/commentary?
01-17-2007 #2
- Jan 2006
- 9
comments, commentary, anything? did I leave something useful out, or put too much in?
After more consideration, I guess I could go up to 600lb/in on the fronts and 200lb/in on the rears. Understand that with the right shock valving (maybe use the hotchkis-valved bilsteins) that this can be very streetable.
I'll add that the hotchkis TVS is actually not that far off from what I'm looking for, though I have a bit of concern that the front springs might be borderline too stiff? Also concerned with the amount they lower the car and that it might be too low for me...
01-17-2007 #31. I'd look at Lateral Dynamics 3 link for the rear:
Originally Posted by 71rs
http://www.lateral-dynamics.com/
2. S.C. & C. Package is a tough one to beat!
3. You may want to look at some Chassisworks Double Adjustable Varishocks.
Good Luck!
John'66 Chevy II - The "NEW" '69 Camaro!
***Under Construction***
Build Update Link:
01-17-2007 #4
- Jan 2006
- 9
I guess I should mention that I need to stay with the leaf spring suspension for cost reasons. The base kit price for the 3-link is $3600, I'd like to keep the entire suspension under that. Even with the SC&C kit, custom rear leafs and some fancy bits thrown in, I should be able to do that.
01-17-2007 #5I would look at DSE for the rear leaf kit then..........
Build Update Link:
01-17-2007 #6
