Results 1 to 10 of 10
Thread: Engine painting?
11-29-2004 #1
Engine painting?
I would like to paint my LT1 prior to installing and would like to do it right. What type of prep do I need to do (sanding, stripping)? Once all that work is done what type of paint do you use that can be sprayed using a gun. My concern is the paint not sticking, falling off or just burning off?
Bruce
11-30-2004 #2I'd suggest hot tanking the block if you really want to paint it right. I have never been able to just 'clean up' a complete longblock before and have the paint come out nice. It's always iffy at best because there is almost always some oil left on it.
If you're okay with the stock colors you can use some hi-temp engine enamel (rattle can). It accually works really well for most jobs. If you want to spray it I would use Eastwood or POR-15 products. You're normal single stage under hood PPG or Dupont paint probably won't withstand the heat although I've never used it before on a block. If you spray the block make sure you clean your gun out really well or you'll ruin it with the Eastwood and POR-15 paints. (I learned the hard way)
Hope this helps.~Ryan
11-30-2004 #3
Banned
- Aug 2003
- Orlando, FL
- 8,745
Painting
We strip the block one way or another. If it is a bare block going to the machine shop, it is dipped. If it is a complete motor just being painted, we either use striper, or sandblast. Obviously if you sandblst there is a mega amount of time in sealing ports.
Either way, once it is bare metal, we use zinc rich self etch primer and high end single stage urethane automotive paint. You can get any color you want, it is shinny, and durable. The self etch with prevent peeling, as long as all the oil is removed first.
Heat is not an issue, good surface prep is everything.
11-30-2004 #4engine paint
Thanks for the input. The motor is used and just needs to be cleaned up and detailed prior to install.
Bruce
11-30-2004 #5
