    Results 1 to 9 of 9
      Jan 2007
      Gresham, Oregon
      turbo with blow through carb
      Can I get some pros and cons of using this combo with a 302 chevy and a 4 speed auto in a first gen firebird. I have all the parts except for the carb.
      Dan
      Oct 2006
      Ottawa, Ontario, Canada
      I would contact Kevin @ CSU for the carb......his service & product is really beyond exceptional.
      I currently use a blow-through system.....drives great on the street & works even better once your foot is down ;)
      -Carm
      '69 Firebird Twin Turbo SBC 400" Blow-through
      9.80 @ 141 w/ 1.88 60-ft..... on 17's
      9.21 @ 153 w/ 1.45 60-ft..... on PUMP GAS
      8.60 @ 164 w/ 1.46 60-ft..... on RACE GAS
      I modified my 750 holley dbl pumper thats on my twin turbo vette and it runs really good. I used these instructions.
      http://www.hangar18fabrication.com/blowthru.html
      Turbos, 1700.00
      Hot Side, 1500.00
      Cold Side, 1,000.00
      Fuel System, 1,000.00
      The look on the face of whomever the passenger is when the tires break loose at o say 70 mph or so........priceless
      Oct 2006
      Thats a great article as well if you want to tackle the carb modification yourself, i shouldnt of left that out of my other post!
      Use a good fuel system as well, you can never shy on that
      -Carm
      Central Florida
      We are using a CSU on my buddies 67 nova it works great ad csu have been over the top on customer service and tech advice
      www.carbonfibervalvecovers.com
      Four0Seven-330-2056
      Jan 2007
      Gresham, Oregon
      Thanks for all the good info. I am sure that I will be using a dual T-3 set up. I think that it will be cheaper and easier than plumbing exhaust for a single turbo. So I think that I will go the cheap way and try to do it myself. (hope its cheaper)
      Dan
      Oct 2006
      Definetly the cheaper way lol......now as for EASIER with a single, its possible but i think the outcome is the same.
      On another note, KEVIN from CSU just messaged me & follwing up - Hows that for a great product, service & support...hands down CSU!!!!!
      -Carm
      What/who is CSU??
      Texas
      Those carbs work great. Alex's car (twin turbo Camaro run-in) has a CSU Holley 850 on it. I can honestly say that the only change I need to make is one step smaller on the low speed air bleeds. It has a slight stumble at very low speed/low rpm at light throttle. Wide open (well, almost wide open. I haven't floored it yet) performance seems to be pretty close. We are installing data logging equipment so air/fuel ratios can be checked. Along w/IAT temps and boost levels.
      Something else. If you happen to have a Holley HP series carb laying around, CSU can mod it for you. Lowering the cost of having to buy one of their "cores".
      I did pull the bowels off, before I installed it. The secondary power valve looks more like a big jet w/a suction tube pointing bownward and the rear jets have extensions. It looks pretty cool w/the choke horn milled off.
      Oh yeah, one more thing. It's not cold natured at all. It will idle w/foot off the gas within a 1 minute warm up.
