    Results 1 to 20 of 23
      Nov 2000
      O-town
      How to keep Brake Lines from turning or rusty
      I bought a B/L kit from Ricks years back but some of the lines have corroded or gotten rusty in areas, how did any of you keep them from turning,
      I've heard of people spraying them with clear, anything else?
      Dec 2002
      Lost Wages, Nevada
      Wd-40
      CHICAGO SUBURBS
      Stainless steel lines. After replacing the lines twice on the same vehicle, I try to get stainless for everything except a daily driver. FRANK
      Nov 2000
      O-town
      I'm just going to paint them bright silver!
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by Steve68
      Funny, I have no rear fuel & evap lines out of the 77 right now. I've determined it was too big a PITA to try to clean them up. I'm just going to hit them with silver POR.
      The front fuels lines cleaned up perfect, and I will be hitting them with some rattle can clear. My brake lines are all new SS.
      Scott from NJ.
      Vent Windows Forever! ...
      Nov 2000
      O-town
      I don't know what to do maybe I jump to SS,
      Cumberland, Maryland
      Not sure where I saw it but they make an aerosol galvanize coating that make be worth looking into.
      Nov 2000
      O-town
      Most places, weld shops sell that stuff but I think it gets powdery,
      Im not sure, I have never used it before. i just happened across a thread where a guy used it on the metal section of his powersteering hoses after replacing old rusted ones.
      Edit. Post#523
      "cold spray galvanize from my local welding supply shop."
      http://www.corner-carvers.com/forums...ight=galvanize
      Nov 2000
      O-town
      Thats what I'm talking about,
      Northern Indiana
      I've heard of people using Penetrol on metal parts...you can get it in the paint section of Home Depot or Lowes it's a orange and white container. Not sure on multiple applications though,
      "Champagne taste on a beer pocket book."
      How well would it work to powdercoat the lines? just a thought...
      98 Corvette-Z51, 6 speed, 346ci, shaved heads, z06 cam, straightpiped
      67 Camaro- soon to be completely overhauled!
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by JChristian1835
      Some lines are pretty long.
      Scott from NJ.
      Quote Originally Posted by BonzoHansen
      Well I know that.. but I've seen some huge powdercoating ovens. I just didnt know how durable it would turn out..
      Aug 2005
      Hamilton, NJ
      LOL
      I'm not sure it would work under the line nuts.
      Scott from NJ.
      yea true.. didnt think of that.. it'd have to be a very very thin layer...
      Aug 2005
      Hamilton, NJ
      I'm no P/C expert, but I might guess you'd have to put them on afterwards, thus flaring them post-coating.
      Barbed fuel lines, however...
      Scott from NJ.
      I have no real experience with powdercoating either.. i was just throwing the idea out there... surely there should be an alternative to spending the money for stainless steel...
      Los Angeles
      Cheapest and best method would be to get a roll of 3/16" stainless tubing and bending it yourself.
      While the bending is pretty easy, the double flaring of stainless can be tough.
      I have a craftsman double flare tool and it's a pos for steel. I just bought the tool that CPP sells, it's their top of the line one, and it worked pretty well, but I only used it on mild steel.
      Otherwise, from what I have seen asked here, I'd go with the POR 15. Powder coating may cause seal issues, and it might soften with brake fluid (probably will). Or, you might try epoxy paint, but again, might soften with brake fluid. Of course, if you run DOT 5, you wouldn't get the fluid softening the paint problems, but there are other problems with DOT 5.
      May 2002
      Northern California
      move to california...but seriously I think your rusty lines are the least of your problems. Paint everything semi gloss black.
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
