Results 1 to 17 of 17
Thread: Air lines for compressor
01-09-2007 #1
I have a new Ingersol Rand 2 stage compressor on its way, so I've been planning out my air lines etc. I've looked at a couple of sites that give recommendations for how to set up your system. I went to Home Depot and Lowe's today to get some ideas, but some of the recommendations dont make much sense to me...
The compressor has a 1/2 inch NPT outlet, and I use 3/8 air lines for my tools. Do I really need to run 3/4- 1 inch hard air lines around the shop ?? The way my garage is set up, I only really need about 25-30 feet of hard line, and there will never be more than one tool working at the same time.
I understand the advantage of hard steel lines to get the air temp down and get the moisture to condense before my filter/water trap etc, but with a 1/2 inch outlet and 3/8 flex air line, what the point of having 3/4 inch hard line between them?? Wont 1/2 inch be just fine ??
If I want to run 3/4 inch line, its just going to take more step up/down adapters to get it to work. Seems like alot of "bottlenecks" in a system like that.
Second issue... the diagrams I've found for layouts all have flex lines form the compressor to the hard line on the wall... I cant find short hose lines other than 3/8 inch.
Ned
Manteca, CA
My '69 Camaro
My Camaro Movie
My '70 Cuda Project Thread
My Cuda Project Pix
Cuda Project Sponsors/Builders
Bruning Auto Design,
Bowler Transmission, Air Ride Technologies, American Autowire, Vintage Air, Comp Cams/F.A.S.T
Carter Hickman Designs
