    Results 1 to 3 of 3
      Aug 2003
      Prescott Valley, AZ
      tick tick a-tick tick
      I just finished installing Comp cams 213-3 complete kit. On cylinder #2 exhaust there is a definite “tick” noise coming from the lifter. I swapped lifters and the noise remained. I contacted Comp cams tech help and they gave me the “I don’t know what it is” answer. I got a “it might be a bad lifter” at the most. What do you all think? Most everybody said to put 500 miles on it and reevaluate the noise.
      It's shake and bake!!! and i helped!
      Drewco Homes
      Mar 2002
      Redwood City, CA
      Have you checked for an exhaust leak? How about the intake gasket? Those are very common. Also, take a look at the pushrod and rocker. Just make sure you get every possible angle on it.
      Allen Ortega
      Aug 2003
      Prescott Valley, AZ
      yup, i checked out the pushrod and rocker. i put my stethascope (sp) thingy on the adjusting nut and found the noise. it doesn't start untill about 5-10 seconds after startup which would tell me hydraulics.
      Drewco Homes
