Results 1 to 19 of 19
Thread: Lateral effects
12-20-2006 #1
- Dec 2006
- 10
Lateral effects
I'm in the throws of finishing the suspension on my 70 Cuda'. The front suspension is an RMS AlterKtion with PS rack, adjustable QA1 shocks and 500# coilover springs. The front anti-sway bar is a 1 1/8" diameter solid bar with a 9.5" effective torsion lever.
The rear suspension is a modified Alston Chassisworks ProStreet 4-Link with Panhard. It is sprung from adjustable VariSpring shocks and 176# coilover springs. The lower bars intersect the road surface at about 200" in front of the rear axle centerline and the upper bars intersect the lower bars at 174" in front of the rear axle centerline. The bars also splay outward from the front pivot to the rear pivot at 3 degrees to set the shocks/springs as far outboard on the axle as possible. The rear stablizer bar will be a splined 7/8" with arms to the outside of the frame rails. As this car will have over 1200 Horsepower and a manual transmission I needed to intersect the bars so the suspension will take a set and transfer weight to the rear upon acceleration rather than jack the rear of the car. However, lateral handling is the primary objective. The chassis is lowered to 8" from the ground measured from the sill bottom rail.
The issue I am trying to understand is the handling effects due to where I had to install the Panhard bar; it is parallel to the axle at ride height but just above the center section (see photo). I realize the roll center is above the axle centerline but don't really understand the overall effect. I'm not opposed to relocating it but will cause havoc with the fuel cell placement.
Tom
12-21-2006 #2
Full Blown G-Machiner
- Aug 2004
- Boston MA
- 686
I wrote a huge response to this post but it didn't load. Oh well. Basically it was...
huge rear swaybar+ crazy high rrc= no lateral grip= very loose
174" IC, maybe an inch off the ground= >5% anti squat ("jacking")= no grip= 3sec 60'
Aside from the p-bar, you can tune what you've got to perform well. Cool project, good luck.1967 #s RS
12-21-2006 #3
- Dec 2006
- 10
I here ya... The lower bar forward connect points will be moved up 2 inches. This should get the anti-squat up around 60% but looks to induce a possible slight oversteer condition (I believe). I need to drop some plumbobs off the axle to validate.
Originally Posted by wendell
the question I have is; what is the consequence of having the panhard up so high?
12-22-2006 #4
