    Results 1 to 20 of 23
      Houston, Tx
      4l60e (1996 LT1) - How do I control it?
      I have purchased an LT1 4l60e to use with my 383 SBC and would like to know the best way to control it.
      I know that TCI offers a computer w/ software for about $700, but I hope to spend less than that if I can.
      Is it possible to use a stock 4l60e computer and use tunercat or pcmforless to program the gears, tire size, shift points, etc? Am I missing something? I figure I could get this setup running for somewhere around $350 and save some money.
      Eastern Virginia
      Sorry I don't have an answer for you, but if I was doing the same setup I would talk to John at www.speartech.com. I'm sure he would have an answer.
      Scot
      86 Monte SS
      Jan 2003
      Arizona
      Quote Originally Posted by Taylor1969
      ......Is it possible to use a stock 4l60e computer and use tunercat or pcmforless to program the gears, tire size, shift points, etc?
      Yes. You can do that.
      ________________
      Steve Chryssos
      Jan 2007
      Bedford, PA
      controlling the 4l60e
      convert it to use a vaccuum modulator, would work like a thm350 or 400
      Eastern Virginia
      I don't think you can convert it. You are probably thinking of the 4L60 (aka 700R4) the 4L60"e" is the electronic version, all shift points, forward/reverse & so on is all controlled electronically, not mechanically.
      Scot
      86 Monte SS
      Jan 2007
      Bedford, PA
      converting
      yes you can convert an 4l60e to use a modulator http://www.transgo.com/tough_stuff.php part number 46 mod. ive done it several times for local racers...
      Eastern Virginia
      I see, I was not aware of such a thing. But then I ask this: Why? It has been a few years, but I bought a 4L60 (700R4) that was only 3 or 4 years old for $125. That route seems simpler than buying a conversion kit & taking the tranny apart & convert it.
      Scot
      86 Monte SS
      Jan 2007
      Bedford, PA
      good point
      i would agree, but how hard is it to drop the pan, it is always a good idea to get a unit manufactured aft 2/9/87 since they had problems with the low roller clutch in the ealier units... also i would not use a vehicle with a pwm pump...this in every unit ever built has been nothing but a pain and lead to premature converter failure do to the slip % of the converter clutch and never being able to fuly enguage creates more heat and wear..
      Eastern Virginia
      The one I bought was a 92 & the only thing I did to it was pull the pump cover & switch to a 10 vane pump & hardened ring guides. I think I got it from Art Carr.
      Scot
      86 Monte SS
      Jan 2007
      Bedford, PA
      the 4l60E had less quirks in design that is non-electronic predicessor, but that is just my opinion as a builder
      Aug 2006
      KC
      I would like to go back to original question. Is there an ecomical way to electronically control 4L60E?
      Jan 2003
      Arizona
      I saw your for sale ad. You will need to get an LT1 computer to run your fuel injection. That same computer will run your transmission.
      ________________
      Steve Chryssos
      Aug 2006
      KC
      I would like to keep the 4L60e and put it in a 70 nova. The Lt1 is not part of the set up. Is there a economical way to just contol transmission? Will a pcm control it without the motor? Everything I see is 500.00 would like to find something cheaper.
      (sorry for the hijack)
      Houston, Tx
      Quote Originally Posted by Footjoy
      This is no hijack - it is exactly the question I would like to know.
      According to some of the PCM editing companies it is not possible. We may have to pony up the big bucks form transmission control.
      I plan to keep my th-350 for a while and may even put the 4l60e up for sale and do a t56 in the future
      Jan 2003
      Arizona
      If you will be putting the electronic transmission behind a carbureted engine then you you have no choice but to run a standalone tans computer. There is no inexpensive alternative. To the contrary, the cost goes up since you must add on some form of throttle position sensor or vacuum modulator conversion.
      That computer is quite busy running shift and line pressure solenoids as well as handling other functions such as converter lock up and manumatic capability. The smart computers also factor in engine or trans coolant temperature to help extend transmission life. Sorry there is no cheap alternative, but I hope that I have helped explain WHY the stuff is expensive.
      ________________
      Steve Chryssos
      Houston, Tx
      Quote Originally Posted by streetfytr68
      Yeah... I understand. It is expensive because only two companies can do it . I think that if they reduced the price to under $500 per unit they would be selling twice as many as if they charged $700. Over $500 and I really think that you get people thinking hard on whether or not it is a worthwhile expendature
      I guess that i'll run the th350 for a while and save up 1K to control the transmission
      Edmonton, AB, Canada
      www.compushift.com I used this kit to swap a 4L80E into my dually behind a carbed big block. Plug and play..... complete harness, can be made for pushbutton shifting, and if you get the optional display/programmer you can control most aspects of a 4L60 or an 80E. In my opinion is has been money well spent. Cruise rpm on the highway dropped by 1000rpm. In the first truck I had this trans in, I wasted 2.5yrs and lots of $$$ working with another person trying to make a stock harness, with a stock TCM, with a custom chip work. If I would have known about the Compushift kit, I would have done it in a heartbeat. Do yourself a favor, buck up and buy the kit, do it right the first time and you'll never look back... !!! Just my $.02.... Colin
      Holly, MI
      The Megasquirt computer will control a transmission with the new General Purpose Input Outout (GPIO) board they are working on. The first code is designed specifically for the 4L60E trans. As others have said, it will still require at least a throttle position sensor, but I don't think you will find anything more reasonably prices than Megasquirt components. I don't think the system is past testing yet, but it will be soon. I plan to use this to paddle shift a 4L60E.
      Check out the forum for more information: www.msefi.com
      Ken
      69 Camaro
      427, 4 speed, TTII's, Konis, JL8 clone brakes, solid AL body bushings, some assembly still required
      69 Corvette
      427, 4 speed, TTII's, Bilsteins, HEI, what I work on while the Camaro sits
      Houston, Tx
      Quote Originally Posted by BB69
      Ken
      AWESOME!!! This will definately be my solution when it is available. Initial cost estimates are ~$150 for the board. Add a $20 case and the TPS and I would be well under $500 for a full working solution. I am stoked about this! Ken, thanks for the link!
      Jan 2003
      Arizona
      Cool. Thanks for the link.
      ________________
      Steve Chryssos
