    Results 1 to 12 of 12
      swaybar angles??
      i put in a 1 1/4 swaybar in, and the back of the sway bar towards the back of the car, is were it bolts to the lower a-arm, its angle is quite steep from lowering the car, will this harm the performance of the bar? do i need to cut the sleeve spacer? so i guess my question is should the bar sit level?
      69 camaro, 383 stroker, 700r, 3:73 auburn, JL stereo, marquez lights front/back, adj qa1's, custom dash, sts swaybars 1 1/4-7/8, global west a-arms/subframe connectors, suede interior.
      http://hobbystage.net/camaro/jigga99/
      Mesa, AZ
      yes it should sit level
      Maine
      Seems to me that if the bar isn't level (i.e., the arms are pointing up or down) that this would effectively reduce the length of the arm and thereby increase sway bar rate.
      John
      Oct 2003
      Arvada, Co
      That is not a good thing. You want them level to the ground. These will help. http://www.guldstrand.com/link.htm
      Brian
      Oct 2006
      So Cal San Dimas Ca.
      Quote Originally Posted by boodlefoof
      OOps wrong quote!!
      Oct 2006
      Quote Originally Posted by baz67
      Hey buddy,were can I find these,and will they work with the standard after market front sway bar,you know the ones that use the common endlink with the 4 bushings and middle sleeve..These links look awesome.You using them?
      Oct 2003
      Arvada, Co
      Quote Originally Posted by nowukno
      www.guldstrand.com The original link was from the Corvette section, but the Camaro section has them as well. I would say they will work as long as they are long enough in your application.
      IIRC, ATS also had some in the works. Now with everything else on their plate who knows if they will get them done.
      Brian
      Central CA USA
      Keep the links a little bit on the long side for a first gen Camaro. They also swing side to side on the bottom end when the lower A arm moves up and down. If they get too short, they will pull sideways on the bar and create a bind. If you have conventional polly bushed end links, don't over-tighten them, especially if the anti-roll bar arm ends are not level, it will bind. It's the eye end of the arms that matters.
      good info thanks
      Dec 2002
      Lost Wages, Nevada
      Use of the 63-82 Corvette end links will solve this issue.
      Energy Suspension part number: 9.8120
      its winter here right now so, ill let you know how it rides in 3 months hahahaaha
      Fontana, CA
      My local Autozone has an array of different length Energy suspension endlinks, as I think most autoparts stores do. Just measure and find the right length. As Dave suggests make them a little longer and do not overtighten.
      Nick R.
