    Results 1 to 8 of 8
      Nov 2004
      Delaware
      Aluminum Radiators ?
      Whats the best aluminum radiator set up most are using to fit 1967 Camaro/ Firebird?
      Nov 2004
      Delaware
      Help please!!! Nobody has any suggestions. Any recommendations would be appreciated. I am probably leaning to R Davis.
      I used a factory radiator and fans out of the 99 Camaro. Works good for me with the ls1.
      Please see my PT Garage for more info on ProBell Camaro. 67 style,99 comfort, options and drive-ability with NASCAR Late Model suspension front and rear.https://www.pro-touring.com/forum/vb...?do=view&g=106
      Car Domain PG
      http://www.cardomain.com/ride/2565383
      NJ
      do a search, this topic has been pretty well covered. You'll find that most will recommend Be Cool or Ron Davis. I've had both and would lean toward the Ron Davis if its in your budget.
      Check your mail. We build them with HD Mark VIII fans and Spal pwm controllers installed also! A nice radiator alone won't shed much heat. You need to figure out how you want to pull the heat out, and for that, nothing beats a Mark VIII fan!
      Gmachinz Sales and Performance
      "updating the level of performance..."
      [email protected]
      *never argue with an idiot-they'll drag you down to their level and beat you with experience!*
      NE OHIO
      Quote Originally Posted by dmastrota
      Did you get my PM?
      montreal CANADA
      take a look at jegs and summit mail order parts, thay have rads made by becool and griffin, thay also have universal fit rads that are not to expensive, but if your running a modded engien, the stock rad might not keap up with the cooling demandes of your motor, it all depends of what you do with the cars and if the motor is modded or not, i got a pontiac 461 stroker and the stock rad didn't even do the job, i would have to pull over alot to let it cool a lil, i put in an aluminum rad by becool and now its great, no more overheating.
      Fontana, CA
      I suggest AFCO!
      Nick R.
