    Results 1 to 10 of 10
      May 2002
      Southeastern WI
      Speed calculator
      Is there a calculator out there that will estimate top speed taking Cd into account along with HP and gearing, etc?
      Jeff
      Jeff,I don't know if there is a calculator or such,but it sounds like you might be planning some sort of high speed event?If so which one?
      I'm in the process of getting ready for an open road race event (unlimited speed) in spring 07 and and will be starting 1st shake down run on a set of 247 gears this weekend.68 camaro.
      Jerry
      Camtender,Privateer by choice
      Member of Hot Rod Power Tour Long Haul Gang 03'
      Winner of the 2nd annual Pro-Touring.com Run Thru The Hills drag racing event sponsored by Musclerides.com 06'
      2nd in class @ Big Bend Open Road Race 07' http://www.youtube.com/watch?v=Nti3UarUwzU
      Record holder @ The Texas Mile 08' for 1st gen. camaros http://www.youtube.com/watch?v=lvEzlnnAB8I
      http://www.youtube.com/watch?v=6L0sYaMnni4
      France (for now)
      Here is a little spreadsheet I did a while back...
      I was laid up with a bad back for a few months and got bored, so I wrote this. The second page has a top speed estimator in it. I never validated it, but I think it's correct...
      Let me know if you need help understanding it. I wrote it for myself with no real intention of someone else understanding my bizarre thoughts while under the influence of pain meds!
      Good luck!
      Attached Files Attached Files
      Tireman,did you forget to attach a link or something?
      Ok, I see it now.Computer will not open file
      Central CA USA
      I don't see rolling drag in your sheet.
      Read this: http://www.mayfco.com/cobra.htm
      May 2002
      Southeastern WI
      Quote Originally Posted by the camtender
      Jerry
      Not really planning anything, just curious. Any idea what the approximate Cd is on a 67 Camaro?
      Tireman, why do you have 2nd gear ratio and what criteria do you use to estimate drivetrain efficiency?
      Jeff
      Central CA USA
      Here is an Land Speed Record site with several spreadsheets:
      http://purplesagetradingpost.com/sum...eet-index.html
      Central Valley Ca.
      I have a tool that was made by Erson Cams. It has a speed calculator on one side, and a valve computer on the other. It's a circular slide rule.
      Detroit Subs
      Quote Originally Posted by ITLBTU
      Ah! The ol' Erson "dream Wheel" !
