    Results 1 to 11 of 11
      polk county,FL
      Disc brake rear?
      I have a disc rear from an 81 T/A in my 80 Z28.Does anyone sell upgrades for these rears,such as better rotors and calipers?
      There are slotted, drilled or combination rotors available for your application.
      The calipers are problematic with the internal parking brake. You must religously use the parking brake to keep these calipers working properly. Check you calipers before installation as the pistons may already be seized it the rearend has been sitting. I am not aware of an upgrade caliper that will bolt on the same/stock caliper bracket. To upgrade calipers and size of rotor you will need to replace everything. If you do that, you have defeated the purpose of purchasing/using the T/A rearend.
      Mike
      www.musclecardeals.com
      Jun 2006
      Katy,TX
      The best thing for the rear caliper is go buy some lifetime warranty rebuilts. Then when the piston sticks and the parking brake mechanism doesn't work swap them for free! They have a decent sized piston.
      Another option is using 81 Malibu right front calipers(same mounting spacing) on both sides on the rear and having no parking brake.The brake hose is in a different location so you would have to change that.
      If you are a good fabricator I would think you could use the rotors and make a bracket to use a better caliper/parking brake on it.
      Chico, California Nor-Cal
      Don't scare the guy! I have used them for 15 years! I haven't rebuilt them, but i try and use the parking brake every once in a while. They work good and are cheap. You may have a tough time buying pads, but.... If you buy a set of front metric pads, and add the little pin that keeps the piston from rotating when the parking brake is applied, you will have any pad you like and can match to the front
      Keith
      Jun 2006
      Katy,TX
      They've been on my TA for almost 20 years! I have noticed now they cross reference a front pad that has different "bumps" on it than the old dedicated rear pads did.
      Harriman, Tennessee
      SSBC Brakes sells a caliper that will bolt in place of the stock units. Looks nice and retains the parking brake, but as I haven't used them, I can't comment on the quality.
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      www.FQuick.com/ProTouring442
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Jun 2006
      Katy,TX
      That's interesting I hadn't seen that caliper. I thought most rear disc setups used a different spacing/bracket on their calipers.
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by ProTouring442
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      They don't list anything on their site as stock replacement. Any idea which ones?
      The TA rotors are 11.25" or so, right?
      Scott from NJ.
      Vent Windows Forever! ...
      Harriman, Tennessee
      If I remember correctly, it's the "Force 10." Give 'em a call to confirm.
      http://www.stainlesssteelbrakes.com/...ipers/sportR1/
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      Aug 2005
      Hamilton, NJ
      Thanks.
      Scott from NJ.
      Jun 2006
      Katy,TX
      That looks interesting, I wonder if it's the same ratchet piston the GM ones had?
