      Near Dayton, OH
      Stock hydroboost setup
      I have an opportunity to buy a complete hydroboost setup off an '81 Cutlass Supreme that originally had a diesel engine.
      Would there be any benefit to picking this up for my '87 Cutlass? I want to convert mine over to a hydroboost setup but didn't know if the older units would work as well as the new hydratech systems?
      Can an older hydroboost unit be upgraded at all for better performance?
      1987 Olds Cutlass Supreme FE3X Clone
      EFI455/T56/9" w/ 4.30 gears
      __________________________________________________ __
      northern california
      the effieciency is much higher on the newer design units, and will require less line pressure to create the same amount of force, requireing less horsepower to drive the pump. Just step up to the new unit of your going to do it, i bought mine for a 1 1/16 bore chevy master cylinder for $500 for a complete kit ready to install, well worth it.
      Harriman, Tennessee
      Those old hydroboost units had a rust preventative feature that the new ones don't. Once warmed up, they tended to spray anything within 2 feet with power steering fluid.
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      www.FQuick.com/ProTouring442
      "You can never go home again, Oatman...
      But I guess you can shop there."
      Lead.
      LEADFOOT1
      1969 Camaro Pro-Touring project SOLD!!!
      NOW; as of 08-2006. Still a 1969 Camaro, BUT now a Convertible!, A 63 000 miles, 1 owner, 1 repaint in '78 that was stored inside from 1982 'till i got it car, and is now; Full custom tubbed to fit 19x8.5 and 20x13" Forgeline ZX3p wheels, w/345'-25-20's rear, C6-Z-06 brakes.
      AirBAr suspended +++
      1998 Dualie Crew Cab 3500/454 Fully Loaded.
      The older ones had an internal reservior, so they're smaller. But I would, and did, go with a newer type 2 style. All the newer ones look the same externally but have different bores inside. I used an Astro van unit which was one of the biggest ones I found at the wreckers.
      http://members.shaw.ca/pekpress/HydroboostSwap.html
      I went with the newer set up too. Some later moder l10's have the hydroboost with the reserve canister (co2) I think....
      Anyways its alot cheaper for you and I being that we have the g chassis and they came with them from GM. Be sure to get the pedal because some of the diameters are different on the brake pedal stud. I did a 84 GN hydroboost on my malibu. Have yet to use it but mabye in the next 6 months.
      Oct 2006
      Norway
      G20 hydraboost
      Is the hydraboost from a Chevy G20 van from -87 a good unit for my Camaro? Any advice or.....
      Olav
