    Results 1 to 9 of 9
      Washington
      Aftermarket LS1 harmonic balancer ideas
      Does anyone know of another manfacture besides Vector and SLP?
      I'm looking for a slightly smaller unit. Something in the 6" to 6.5" O.D. range. I need the extra space to clear my rack.
      Any ideas would be great.
      La La Land, CA
      We use one from ATI on our engines.
      Tyler
      I'm using an ATI on my LS2 too.
      jp
      John Parsons
      Milwaukee WI.
      I run an ATI. It is pretty small, It hurts cooling just a tad though.
      Twin Turbo Ls1 '71 Chevelle
      93 octane 1000 hp street car!!
      Fluiddamper makes one also, both in 10% and 25% underdriven.
      2004 Pontiac GTO
      Bogarts 15x4 front 15x8.75 rear
      BMR Suspension
      Yank 4400 Converter
      Stainless Works 3" Exhaust
      Fast 90/90
      CompCams Custom Grind 228/232 on a 110lsa
      CNC'ED Texas Speed Cylinder Heads
      Custom Tune by Hoosier Performance
      Best ET to date is: 11.33 at 118mph w/ 1.52 60'
      this was before the Fast Setup!
      Jake,
      Are you running C5 accessories or f-body versions? The C5 stuff is about 1" or so closer to the engine, so you might be able to swap over to that ...
      jp
      John Parsons
      Jul 2003
      Anaheim Hills, CA
      I'm running a 4.5 lb ATI unit.
      If you don't run AC you can get it without the rear pulley section. This gives you more rack clearance and cuts down on un-needed weight.
      1968 Track Rat Camaro:
      Washington
      Nope. I’m running the F-body stuff. One of the only reason’s my wife is letting me build this crazy dream car I have is because it has AC. So no cutting corners there.
      Vector dampers look like a sweet way to go however, I’m having trouble getting a hold of Fisher Concepts, who build them.
      ATI looks like the only other option.
      Thanks guys.
      Jun 2006
      Indianapolis,IN
      Jake, We can help you with ATI or Fluidampr. Let us know if you need pricing.
      Thanks Tim
      317 541-9590
