      St.Anne Il
      pontiac to chevy
      ok gonna toss engine i have lying around in my 69 bird its a chevy 383..what do i need motor mount wise to adapt this..ive never been down this road..
      Darrin Stalnecker
      2007 Corvette Supercharged
      1968 Camaro LS1 T56
      Montgomery, IL
      I would think the frame is drilled for either engine so all you should need is the correct frame mounts and engine mounts. Having both a 69 Camaro and a 69 Firebird, I would think you could use the Camaro as a guide. You will need the P/S set up and to move the battery and alt to the other side. TCI sells adapters for the BOP trans bolt pattern to the Chevrolet.
      71 Formula, 455 SD/KRE D-Ports, Crower solid cam, TKO 600, 3:73 Eaton posi. 17" ARE 200s, , 1LE brakes, Koni, Rancho adjustable bars, Hotchkis springs
