    Results 1 to 17 of 17
      florida
      C5 calipers to stock steel lines, what flex line?
      I have everything i need now with the exception of the Banjo line on the caliper to the steel lines from where the old rubber line was. My question is can I use the C5 stock lines and have an adapter or something to connect it to the stock steel drum lines??
      Walla Walla, WA
      Quote Originally Posted by crazyfireman
      I used Earl's braided steel lines for a 1969 Camaro on my '68 with C5 front calipers.
      florida
      Where do you get them and how much do they run??
      Walla Walla, WA
      http://store.summitracing.com/partde...5&autoview=sku
      Use the C5 banjo bolts.
      florida
      Wow 150.00 thats pretty steep for just the 2 lines, anyone have a low budget idea? I know shouldnt slack on Brakes but...
      Cumberland, Maryland
      thats for the set. mine included the 2 front hoses and a rear hose. If i had it to do over id opt for another brand that has the coating over the stainless hose. It prevents dirt and grime from working its way into the weave, and continual fricton could lead to eventual fraying.
      I believe goodridge is one of the companies selling the coated versions.
      Walla Walla, WA
      The board gave you the solution, pointed you to the web site that sells them and explained how the pricing works; did you want us to come over and install them too?
      florida
      Actually that would be great. I appreciate you pointing me in the right direction I was just looking for other options as everyone else does.
      TuoCo, CA
      check touring-classics.
      Steve
      Check it Out Here
      florida
      will do , thanks
      florida
      85.00 for two, now we are talking!!
      Nov 2000
      O-town
      I got my Goodrich lines from Baer, a little more than $85 but I installed them last night, look good, and coated,
      Nov 2000
      O-town
      I would use the GM copper washers, I have found that all others leak!
      Clovis, Ca
      I have used KORE3 lines, give them a try kore3.com
      florida
      exactly what I need, 60.00 for two!! Thanks Dave
      florida
      Just ordered the lines from Kore3, 71.00 delivered. Sounds pretty fair to me, I also ordered the clear lines I will post pics when i receive them. Thanks for the help!
      Lake Tillery NC
      I just ordered a set of brake lines from Kore3 also. They asked me the right questions to make sure I got what I needed. I ordered the black lines.
      Mike
      Michael Tucker
      1968 Camaro
