    Results 1 to 12 of 12
    Thread: New here
      Tucson, AZ
      New here
      New to the site, I am in Tucson and I have a 99 Crown Vic it's an ex Bondurant car built by Rosch
      It has a 99 Cobra drive line lots of fun
      99 P71 Crown Vic Ex Bondurant Instructor Car
      North Jersey
      Very cool! Welcome aboard!
      Steve Ragusa - North Jersey
      2006 Infiniti G35x
      Jun 2002
      Long Island, NY
      Welcome to the site. I like that front fascia.
      Harriman, Tennessee
      Cool! Welcome!
      Shiny Side Up!
      Bill
      '72 442 "Inamorata"
      www.FQuick.com/ProTouring442
      "You can never go home again, Oatman...
      But I guess you can shop there."
      CHICAGO
      Nice!
      I never saw one of those before!
      MY NAME IS REESE NATIONAL FOUNDER OF THE #1 STUNNAS MOTORSPORT CLUB AND THIS IS MY 67 IMPALA SS "STILL STUNT'N". FOR MORE INFO ON MY CLUB LOG ONTO WWW.NUMBERONESTUNNAS.COM
      Tucson, AZ
      there where only 18 made and 3 sold by Bondurant the rest are still at the school here is a build sheet
      Instructor Car
      1999 Police Interceptor Crown Victoria
      ENGINE: 1999 SVT Mustang Cobra 4.6L 4V.
      320 HP.
      Full length Cobra windage tray with modified Mark VIII oil pan.
      Emissions controls removed.
      Custom Bondurant engine calibration.
      Custom H – pipe with catalytic converters removed.
      Borla custom dual exhaust system.
      Custom cooling system including production 6.8L V10 water pump and radiator, engine driven fan with custom shroud and an 18” electric cooling fan.
      1995 SVT Mustang Cobra R engine oil cooler.
      battery relocated to trunk.
      WEIGHT: 4,800 Lbs.
      TRANSMISSION/ 1999 SVT Mustang Cobra T-45 5 speed with carbon fiber blocking rings.
      DRIVETRAIN: B & M Ripper Shifter.
      Custom steel drive shaft with safety loop.
      3.73:1 axle ratio with production limited slip.
      FUEL SYSTEM: Custom 22 gallon racing fuel cell.
      1999 SVT Mustang Cobra fuel pump.
      Custom stainless steel and braided fuel lines
      SUSPENSION:Front:
      Eibach 1000 lb per inch springs.
      Monroe Shocks with custom calibration.
      Winston Cup style 2” diameter solid front sway bar with custom links.
      Modified alignment settings:
      Camber 1.8 degrees negative
      Caster 7.0 degrees positive
      Toe 0.0 degrees.
      Rear:
      Eibach 160 lb per inch springs.
      Monroe shocks with custom calibration.
      Production .708 diameter solid sway bar.
      Production Watts linkages.
      BRAKES: Production Crown Victoria disk brakes.
      Performance Friction 90 compound race brake pads.
      Baer Brakes custom steel braided brake lines.
      Custom brake cooling ducts.
      WHEELS/ 1995 SVT Mustang Cobra R 17 X 9” wheels.
      TIRES : Goodyear Eagle HP Ultra 275/40/R17.
      INTERIOR: 1999 SVT Mustang Cobra instrument cluster.
      Four point safety harnesses at all four seating locations.
      Six point fully integrated Roush safety cage.
      10 lb dry chemical fire extinguisher.
      Halon fire suppression system with four nozzles.
      May 2006
      Northern NJ
      4,800 POUNDS??!?!?!?! Now thats a boat! Have you run it at the track? If so, what times?
      1974 Pontiac Firebird Formula
      1971 Pontiac Firebird Formula Clone
      1973 Chevrolet Camaro
      Tucson, AZ
      I have not run it on the drag strip, but I have on a road course I could keep up with the Vettes and Mustangs in the straights but had problems in the twisty bits, I have a blower motor in the works which will help.
      Fontana, CA
      Very cool car. Nice to add some variety to the mix!! Welcome to the site.
      Nick R.
      Portland, OR
      And I thought the Police Interceptor was slick! I dig
      Ben C. - Sometimes Complete > Perfection - I just want to drive my car...
      1969 Nova 408/T56 | 2003 XJ8 Sport LS2/T56
      wow, that is easily the highest estamit I have heard thus far.
      I've heard from 3800 to 4200... 4800 lbs is pretty hefty. even with a 4v cobra motor
      kevin
      ps. dad just bought a 98 p71 :-) mwahahaha....
      New Carlisle Ohio
      Nice....Welcome aboard!
      PartTime
      Chris Hager
