      Nov 2003
      St. Louis area
      Sand blaster question
      I have been doing a little research on sand blasters in the past few weeks. I've got a 100 lb capacity siphon feed model I bought for $10 at a swap meet that doesn't work very good with my small compressor. It's an older Sanborn 5 hp 30 gallon unit, although 5 hp is a little optomistic. Max working pressure is 125 PSI, although I'm uncertain of the CFM rating. I'm looking to blast mostly small parts for now, like the inner wheel housings before I widen them, a-arms, etc. Does anyone have experience with a pressurized blaster and a small compressor like mine? I'm leaning toward a 5 gallon blaster from Harbor Freight that can run on 60-125 PSI and 6 to 25 CFM. I am currently using Black Magic media if that makes a difference.
      Thanks!
      Nathan
      Aug 2003
      well
      Once you try a pressure blaster, you will wonder how you lived without it. You will however find yourself waiting on a 5HP compressor to catch up, but you may need a break yourself anyway.
      Sep 2003
      Tampa, Fl
      I've got a larger compressor and had a siphon feed blaster. When I tried to use plastic media I found it was just to light and I had to turn the pressure way higher than what was recommended for it. I got a smaller pressure type blaster and it worked a lot better with the plastic media. I am not sure what Black Magic media is but I thought I'd throw that out there.
      Brian
      '68 Chevy Stepside-Fatman, HTH, 8.8, Baer, Hydratech, LS1/T56. I know it's a truck but you gotta start somewhere and I need the challenge.
      Nov 2003
      St. Louis area
      Black Magic is a coal slag media available at Menards. It supposedly causes less heat build up and warpage than sand and it's cheap, only about $4 for a 50 lb bag.
      Ortonville, Michigan
      This what I built for myself a couple years ago.Couple sheets of plywood and some 2x4s.
      5 hp comp. is to small you will find. Pressure blasting is the way to go.Try pure white sand from "Quickcrete" about $3.25 for a 50# bags.
      Chris
      1971 RS Z28 Pro-touring thing......will it ever be done??
      Boring Oregon, go figure:)
      Steer clear of regular sand, the silica dust produced is VERY dangerous to your health. You should always use media that is designed for use in blasting.
      Dan
      Yes sir you are correct.Needed to add that I only use the sand outside in the open.
      Chris
