    Results 1 to 13 of 13
    Thread: Mr. October...
      Aug 2005
      Hamilton, NJ
      Mr. October...
      ...Reggie Jackson, has a car at SEMA, and was just on ESPN2 Cold Pizza. Seems he is working with GM pushing the LSX crate. Here are some screen caps. Dumb sports show, bad shots!
      Check out what appears to be the GMPP logo on those very cool modern 'deluxe' seats. I want them for my 67!
      I posted this at TC too, but I thought you guys might dig it.
      Scott from NJ.
      Vent Windows Forever! ...
      Fontana, CA
      Dude, the pic of 2 reasons reggie is cooler than you has me laughing!!
      Nick R.
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by 6'9"Witha69
      As a Yankee fan, I'd be hard pressed not to take that ring over that car. In fact, for me, it is a no brainer (assuming it is a NYY ring).
      Scott from NJ.
      What type of ignition does that car have? Is it just the coils are relocated off the valve cover or something else?
      Socal, Ca
      I think GM put a lsx 454ci monster in that car. Reggie will probably be selling it at BJ this year, i would assume.
      Aug 2005
      Hamilton, NJ
      He mentioned something about working with Warren Johnson on it, so that might be true.
      I thought I heard about a handful of 'Reggie Jackson' cars being sold - presumably just like that one, but maybe I heard wrong.
      Scott from NJ.
      IN/MI border
      May 2006
      Northern NJ
      That car looks gorgeous. Maybe someone at Sema can take some more pictures...
      1974 Pontiac Firebird Formula
      1971 Pontiac Firebird Formula Clone
      1973 Chevrolet Camaro
      Nov 2000
      O-town
      Shannon, aren't those you're pedals???? if they are nice,
      Socal, Ca
      [quote=BuddyP]http://www.cheersandgears.com/forums...howtopic=13026
      Who makes this pulley setup?
      north central Iowa
      Inside the LSX from GMPP
      The 454-cubic-inch small-block V-8 in Jackson ’s Camaro is based on GMPP’s new LSX Bowtie Block cylinder block and other engine components. The cast iron LSX block was designed for the creation of high-horsepower, large-displacement engines based on GM’s Gen IV small-block engine architecture. The iron block enables engine builders to use traditional displacement-enlarging techniques to create large-displacement small-block engines of 500 cubic inches or more. The LSX block is also designed with a thick deck and strategic cast-in strengthening features that support high-horsepower supercharged and nitrous-oxide combinations.
      Jackson helped build the engine with famed NHRA racer Warren Johnson, who was instrumental in the development of the LSX block. For the Camaro, a simple but effective combination employing a single four-barrel carburetor and carefully matched cylinder head and valvetrain components was employed.
      The cylinder heads are prototype LSX heads, which are derived from the LS7 7.0L engine found in the Corvette Z06. They feature six head bolts rather than five, for increased cylinder head sealing – an attribute that builders of supercharged engines will appreciate. Bridging the LSX heads is a new GM Performance Parts four-barrel intake manifold designed to match the rectangular ports of the LS7 head. The manifold is already available from GMPP, allowing customers to run a carburetor on LS7 crate engines. Atop the manifold is a Holley 850-cfm carburetor.
      An ignition driver is all that’s required to change from stock-type EFI to carburetion, and Jackson ’s engine uses a custom MSD Ignition driver that is designed for GM’s Gen III and Gen IV V-8 engines. With the ignition driver connected to the distributorless ignition system, the ignition timing is automatically set at start-up.
      The bottom end of the engine uses a Lunati rotating assembly with forged parts and Mahle pistons that combine with the LSX heads to deliver a pump-gas-friendly 11:1 compression ratio. A custom-grind camshaft was sourced and Comp Cams supplied the remainder of the valvetrain components.
      At Warren Johnson’s dynamometer facility, the LSX engine produced 641 horsepower and 611 lb.-ft. of torque. More than the peak numbers, however, is the engine’s Kansas-flat power band. The engine makes 520 lb.-ft. of torque at only 3,000 rpm, with torque rising steadily throughout the rev range.
      “The engine makes a mountain of torque at just about any rpm,” said Johnson. “The best part is this isn’t an exotic combination. It was put together with off-the-shelf parts that either are available now or will be shortly through GM Performance Parts.”
      In other words, it’s a combination that is easily reproduced as the family of LSX parts and engines grows.
      To complement the power packed into its 454 cubic inches, the LSX in Jackson ’s Camaro was dressed with powder-coated accessories and custom rocker covers. The engine retains a classic look at first glance, but a second look reveals the individual coil packs and other features that identify it as a 21 st-century small-block. Stainless Works fabricated a custom exhaust system, including ceramic-coated headers.
      sounds like gmpp has some nice parts in store for the lsx crowd.
      Miamisburg, Oh
      I wish GMPP would work with a regular Joe,......you know.....like me!
      Northern Indiana
      WOW that car is nice.
      Scott
      G Force Designs Concepts #004
      "Quicksilver"
      1965 Mustang Fastback
      347/450hp FRPP crate engine,G Force T5
      SSBC 4wdb,Budnik M5's etc...
      SOLD
      2011 GT500
      Ingot Silver Metallic
      Stripe delete
      SVTPP/Elec. Pkg.
      Stock for now
      SOLD
      70 Pro Touring Nova
      572/620ho crate
      TKO 600
      DSE suspension upgrades
      SOLD
