      SoCal
      Partitioning valve bracket
      Ok, I'm an idiot.
      Now that that's out of the way, can someone tell me how I'm supposed to mount the prop. valve with this bracket? I know it's different with this m/c because the ports are on the passenger side, but I can't figure out where it's supposed to go. Currently as you can see I stuck it on the lower stud as that seems the best place but it still doesn't look right.
      May 2002
      Northern California
      proper prop position please, or just prefered
      Well Tom I don't think it will ever look right but we can make it nice???? jk I know there isn't much room there but here are 2 alternatives.
      Mount the prop/combo valve on the frame and run 2 new lines to it.Much like they are mounted on a bodies.
      Mount the prop/combo valve under the master with a modifyed stock manual prop/combo bracket. I thought I had a picture but I don't.
      the first is the cleanest IMHO
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
