      Nov 2001
      St. Cloud, MN
      LT1 PCM Programming with Tunercat
      Has anyone ever used Tunercat to program the computer on an LT1? I am having some troubles getting the shift points set correctly.
      Any help from anyone here or should I try more at camaross.com?
      Jon
      71 Nova LT1/4L60E
      Quote Originally Posted by LT1Nova
      Try the www.camaroz28.com Computer Diagnostic / Tuning forum.
      Tuning Forum
      How do you like Tunercat so far? I have an older version of LT-Edit that I need to update and play with a bit more.
      Dave
      Nov 2001
      St. Cloud, MN
      I like it I guess. I have not used any other PCM reprogramming tools so I have nothing to compare it to.
      Some of the Name for the tables are a little confusing but I think understanding them may come with time and use.
      I've lurked on camaroz28.com's message board for a while but I thought I would check here as there would probably be more retrofits here, not that it should really effect anything.
      I think you can download a free trial version of Tunercat.
      Jon
      71 Nova LT1/4L60E
      north central Iowa
      I believe LS1tech.com has a retrofits section, maybe someone over there can help.
      72 Nova SS, on the back burner for now.
      current cruiser: "The green machine"
      '70 Impala 4drht, 26K original miles, 2" drop springs and large swaybars, drives pretty good for a land yahct in the middle of an ls1 swap, but thinking about changing directions to a duramax diesel swap.
