    Results 1 to 15 of 15
      butt joint weld?
      I cut out a piece of my floor and I made a piece to fit right into the hole so i can just "butt weld" the 2 pieces together. I am teaching myself how to weld. Could someone explain the procedure of butt welding?
      Ryan
      Oct 2006
      asuming your floor is made out of steel , I would say regardless of what type of welder your going to be using ( mig or tig ) that prep would be the most impotant thing make shure it is as close a fit as you can posibly get and it shouldn't be a problem .
      Ryan,
      Really, the technique you'll want to use is called "stitch" welding. Have a search here ... we've discussed it before.
      jp
      ​John Parsons
      Feb 2006
      Elk Ridge, Utah
      Ryan,
      jp
      Is that where you drill holes and thread the mig wire through the holes =)
      ok maybee not so funny
      69 Camaro
      W/D sub, Wilwood 13" brakes Bozeforged wheels 18X10 & 18X12,
      Lateral dynamics 3 link ( custom setup ) Dana 60
      lsX Twin Turbo, soon to come
      Viper T56 in place (Yay)
      Bought a running driving car so I can enjoy it before Im dead
      LD 3 Link Installed into ^^^^^ (Yay)
      Den Helder, the Netherlands
      Country Flag: Netherlands
      Quote Originally Posted by Madspeed
      Yes, it is!!
      The hard part is getting the metal to melt together afterward ...
      jp
      ​John Parsons
      Maine
      If you're experiencing a lot of blow through with thin metal, hold a strip of copper against the backside of the joint.
      John
      Apr 2002
      I'll update my welding thread tonight. I'll have pics of fillet and butt welds both in the verticle and horizontal positions.
      --JMarsa
      Quote Originally Posted by JMarsa
      --JMarsa
      sweet!!! that would be helpful.
      Thanks for all the info everyone. I am still a little confused. What is the difference between a stitch weld and a tack weld?
      A quick search turned up this thread ...
      https://www.pro-touring.com/forum/sh...ht=stitch+weld
      jp
      ​John Parsons
      thanks again for the info. I think I understand how to weld a filler piece in.
      Is there a maximum size gap between the 2 pcs of metal? In other words...should the 2 pcs of metal be tounching or should there be a gap of i.e. 1/16" or 1/8"
      If you are welding sheet metal, the best way to ensure warpage is to leave a gap. The hot tack welds will tend to contract, narrowing the gap. That will be happening all the way around, putting a lot stress into the area. The result is usually unplanned warpage.
      In other words, it is better to not leave a gap if the resultant panel is otherwise not firmly held in place by other forces such as braces, crossmembers, or even bends or rolled beads.
      jp
      ​John Parsons
      the gap between a butt weld is suposed to be half of the material thickness. how ever if its sheet metal just butt them right together
      --JMarsa
      Where is your welding thread? I looked and didnt find it.
      Apr 2002
      It was: https://www.pro-touring.com/forum/sh...ad.php?t=22726
      I never updated it like I said i would. My welds are much better now. I've moved onto TIG. I can post some samples but I think Miller has some really good examples on there site.
      --JMarsa
