Results 1 to 15 of 15
Thread: 69 camaro motor mount question
Hi,
can someone answer a simple question for me. Is there a difference between 396 BBC motor mounts or 454 BBC motor mounts??
I am in the process of building a 69 camaro with a 454/TH400 combo. I need to buy motor and frame mounts and everytime I look the motor mounts up they say they are for a 396 in a 69 camaro. I don't see how there could be a major difference but I dunno. any help me shed some light on this??? thanks in advance.
I know that i need BB frame mounts, but does it matter if I buy 396 BBC motor mounts etc. or any BBC 69 camaro motor mount will work?
1969 Camaro PROJECT 454/TH400, 18" and 20" COYS C-5. Second owner, protect-o-plate. Pro-touring on a budget if there is such a thing.
:3gears:
10-11-2006 #2frame mounts are the same. there could be a slight differance with motor mounts should be the type 1 2-7/8 wide. if you need any more help let me know im a dealer for oer goodmark and classic industries.
barry
10-11-2006 #369 Camaro's never came with a 454, so they won't be listed in any parts book. The 396 listing should work for you.
10-12-2006 #4Are you sure that the frame mounts are the same for and small block and a big block? Because they are like $40 difference is price and it look like the mounting holes are different.
I know that 454's never came in a 69 camaro but if 396 mounts will work then that will be great. thanks.1969 Camaro PROJECT 454/TH400, 18" and 20" COYS C-5. Second owner, protect-o-plate. Pro-touring on a budget if there is such a thing.
:3gears:
10-12-2006 #5
