      7/8" master questions
      In my neverending quest to improve my braking system, I ran across this thread.
      https://www.pro-touring.com/forum/sh...t=7%2F8+master
      They recommend some smaller masters that were designed for disc/drum applications. The one chamber is much smaller than the other.
      Are these going to work for a disc/disc application?
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Aug 2001
      Connecticut
      I'm not sure on that, but you can adapt the newer corvette ones to fit pretty easly- I did it on my '68 using a '92 vette master cylinder, and I just picked up a '99 one that appears the same for use on my '69. (15/16 bore if i remember right) -Dan
      1962 Corvette 327-340hp stock
      1967 Corvette L79 convertible
      2006 Corvette Z06
      2011 Corvette GS convertible
      The 99 vette master is a 1" master and I really need something either 13/16 or 7/8" for a manual setup. I am already using a 2001 vette master and I am just not happy with the performance.
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Aug 2001
      Connecticut
      Ah, I haven't measured the '99; I thought the '92 was 15/16, but I'm not running manual-- sorry.
      2006 Corvette Z06
      So will any of these work for a disc/disc setup? Is the rear resevoir big enough for C5 rear calipers?
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
      Charlotte, NC
      let me start by saying I am no brake Guru
      Lots of things go into sizing a master. To find the best master for your needs go on to Tilton's website and they have a work sheet that will ask you weight of your car, tire diameter, number of pistons on your cailipers, power or manual set up, etc and they will size it for you.
      I am running manual brakes but with a twin master set up. 7/8 for the front (C5 calipers) and 1 inch for the rear (wilwood 4 piston)
      Hope this helps
      Feb 2006
      SoCal
      the stock LS1, one, works like a charm for me. i've got big single pistons in the front, and OEM LS1 discs in the back. I'm upgrading to C5Z06 brakes this week, i've got no doubt it'll work well, as C5 front pistons are smaller than LS1 front pistons by a small margin.
      1967 Camaro RS
      LS1, T56, LT'S, LS6 intake, ASP pulley,C6 Z06 clutch, Detroit True-Trac, 4:10 gears, GM 8.5 rear, strange 30spline, HOK Cinnamon Pearl Paint.
      Aren't you using the LS1 master with a booster? I am looking for a manual setup.
      Jeff
      1970 Corvette
      LS1 & T56
      C5 Z06 Brakes
