Results 1 to 11 of 11
Thread: Bad to worse (pulling)!
10-08-2006 #1
I have had an Ls 1 12" swap done for quite a while with pretty good results, except some brake drag on the drivers side and that I am only able to lock up the passenger side front brake on HARD application.
I recently had the drum hub (Drvr side) additionally turned down which stopped the dragging issue due to the hat of the rotor not seating 100%.
I also re-plumbed the drivers hard line and replaced the caliper thinking that was the issue prior to realizing the hub was the Drag causing culprit.
To give the correct time line on what I have done,
1. re-bent hardline, rebled and brakes worked well.
2. autocrossed car 2weeks ago and brakes worked well but dragged on drivers side (drag could only be noticed by wear on the rotor and jacking up the wheel).
3. turned hub and replaced driver side caliper and turned rotor.
I drove the car today after reassembly and I am getting a very hard pull to the passenger side.
The brakes were bled thoroughly and pedal is firm.
I am very frustrated due to fact that the brakes were working well aside from the dragging prior to all this work and now the Pulling has been amplified x 20. My first thought is air in the drivers side caliper but; pedal is firm and system has been bled, and passenger side always seemed to get more pressure.
Why would one side with more hard line get more pressure to the caliper?
Please help, it has to be something simple, the symptoms I had have now gotten worse (aside from drag)!
I have a vacu-bleeder and have used it before and still not made any real difference.
It is like to drivers side is not hardly getting any pressure compared to passeger side now!
SS
