    Results 1 to 12 of 12
      Mobile, AL
      18x11's on a 67 Chevelle
      What is the widest wheel and tire combo I can run on the rear of a 67 Chevelle. I would like to put 18x11's with a 295-35-18 or 335-30-18. Is this possible for a stock susp. car? Thanks guys for the help. Cory
      Loganville, GA
      Corey,
      Generally a 10" wide wheel is about as big as you can go without mods. The rear wheelwells on my 67 el camino are 12" wide inner wheelhouse to outer wheel lip. You can cut the outer wheel lip some but watch for the outer wheelhouse as it comes in about as much as the lip just above the lip. The lower the car sits the less room you will have. Take alot of measurements to see how much room your car has to see if the larger wheels will fit. I'm not sure they will fit without modifications. Good luck.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Southern NJ
      You are going to have trouble with anything wider than 9.5", unless you're willing to do some cutting.
      Matt
      1965 Pontiac GTO – Spotts 421 Tripower | TKO600 | 3.90s | Vintage AC | Baers | Hotchkis/SPC/BMR Suspension | Intro Vistas | BFG KDW Redlines | 06 GTO Seats
      wheels
      I have 9.5" rears w/ 5.625" BS on my '66 running 275/17 rubber. There may be room to go to 295's (there's some room inboard toward the trailing arm) but it would be tight and not allow much room for movement under dynamic driving conditions. Don't see any way a 335 would go without significant mods.
      Sounds obvious but make sure you have your suspension and brake package finalized first as those obviously impact where your wheel mounting surfaces are. The Bear package I decided to go with sometime after buying the wheels moved the mounting point out at least 1/4" per side. I had to roll the fender lips to get the needed clearance.
      Bob
      Mooresville, NC
      '66 Chevelle SS (461, T-56)
      https://www.pro-touring.com/forum/vb...?do=view&g=274
      Aug 2006
      There is a guy on TC with 11 inch wheels. Whe says he has no issues, not tubed either.
      Edit: his car is a newer chevelle, I think we have more room that you guyz.
      1970 chevelle - awaiting heart transplant
      Nov 2002
      Georgetown,TX
      Quote Originally Posted by jfman
      Sorry,a 10" wide wheel on a 66-67 is about it.
      68-72's have larger wheelwells and can handle a 11" wide wheel.
      i have a 72 chevelle and would love to put a 11" wheel on it any idea what the back spacing should be?
      Apr 2003
      Central Valley, CA
      What Clint said. You'll have to be perfect to fit a 10" wheel under the back of a 66-67 Chevelle. Even a 285/40/17 on a 17 x 9.5 is tight under a 66/67, and does rub a little when you really flex the rear end like going into a steep parking lot entrance at an angle. You could probably squeak a 10" wheel and a 285 or 295 18" tire under a 66/67 if you trim/roll the fender lip and pound out and flatten the bead in the inner wheelhouse just above the fender lip.
      Quote Originally Posted by QUINNMOTORSPORTS
      You'll have to measure YOUR car since an 11" wheel is at the ragged edge of what fits... but assuming you have a stock width rear end typically about 6-6.5" of backspace is required to fit an 11" wheel under a 68-72. I run 17 x 11 with 285/40/17, 6.5" backspace, with no cutting needed. About 5/8-3/4" of room to the inside and the outside.
      1969 Chevelle
      Indiana
      I have a 66 El Camino with 18x10 and 295/40/18 Nittos. The only mods I made were trimming the fender lip and rolling what was left of it. I have plenty of room on either side of the sidewall. The backspace is 5.5". I can send or post pics when I get home if you're interested. There's also some pics in my PT Garage.
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      crap this isnt looking good for me.. I was hoping to get a 305/35r18 nitto 555r under mine with an 18x10... crap crap crap
      mo
      A 18x10 is actully a 11 wide wheel,so if you go with an 11 wide it will be a 12 wide.
      Indiana
      Hot66ss, I was thinking about moving to 305/35/18's because I'm starting to get tired of the look of the tall 295/45 (I made a typo above, they're 45 series, not 40) I'm currently running. If you go this route let me know how it all fits. I think the 305 will fit fine but haven't tried it yet.
      Herb
      1963 C10 454/4L80
      PHR CHP CHP youtube
