    Results 1 to 20 of 25
      Maine
      LSx engine 180 degree headers?
      Hey guys,
      I've been looking around here and on LS1tech and I was unable to find any information about whether 180 degree headers would be of any benefit on an LSx engine. I realize they use a different firing order than the Gen I engines, but would there be any benefit to be had by using some sort of crossover headers?
      Clearance/space considerations aside...
      John
      Dec 2002
      Lost Wages, Nevada
      You could alleviate any firing order issue by changing the individual tube location in the collector. So in effect, all the 180* header theory would still there.
      Mountain View, CA
      So do we have anyone savvy in the ways of header building and the space constraints of an LSx/1st Gen Camaro that can tell us if this is doable or cost/difficulty prohibitive.
      True T.
      My blog
      First, does anybody know what the expected benefit is? How much hp gain are we talking about?
      jp
      ​John Parsons
      Mountain View, CA
      Even if it was a wash (which it isn't) I'd still be interested, depending on price, based on the sound alone.
      True T.
      My blog
      Huntington Beach, CA
      Ok I'm a nub. Care to explain the 180* theory?
      Mountain View, CA
      This explains it for an FE. I think on a bow-tie you swap the two center cylinders from each bank.
      True T.
      My blog
      180 theory is that if you get the 4 primary tubes to a collector at 180 degree intervals then you make collector as efficient as possible.
      Take the LS1 firing order: 18726543. So one collector needs 1, 7, 6, and 4; and the other gets 8, 2, 5, and 3.
      As you can imagine, the fabrication/packaging difficulty of such an arrangement in a normal passenger car is substantial.
      jp
      ​John Parsons
      Mountain View, CA
      True T.
      My blog
      Missouri
      Here is a Corvette with 180 deg headers.
      Sean James
      69 Firebird - Build Thread
      72 Firebird
      Indiana
      Quote Originally Posted by Jimmy Sean
      That sounded awesome! I need a set for mine! Any chance of knowing the brand of header?
      Herb
      1966 Chevelle 509/T56Magnum
      1963 C10 454/4L80
      PHR CHP CHP youtube
      Indianapolis, IN
      Come on John, we can build a set, I ain't scared. Be a hell of a project.
      Packaging is always a bear with any front mounted engine in a stock style chassis. We used them a lot in late model stock cars and modifieds where the chassis is svery wide open.
      I can not imagine that Corvette has tubes shorter then 40-45" to make it work.
      Mike Norris
      Mike Norris
      Missouri
      Quote Originally Posted by Yelcamino
      I believe this thread is speaking of the car in the video.
      http://forums.corvetteforum.com/show...232&forum_id=1
      Sean James
      72 Firebird
      mo
      sounds to importy for me, I dont like it.
      We used to run them circle track racing, and found a good set of crossover made more power.
      I think a good set of equal lengths with merge collectors would be better.
      Thall shall fear no amount of boost, For thy bottle is with me.......
      California
      Quote Originally Posted by rocketman
      At least I'm not alone. I don't think it sounds all that great, honestly.
      Matt
      Auburn, WA
      Quote Originally Posted by DarkoNova
      Matt
      You gotta hear it in person. It's awesome and you'll recognize it every time.
      Matt Jones
      Mechanical Engineer
      Art Morrison Enterprises
      Mountain View, CA
      I've seen that video before and ATI comes to mind. Could be wrong.
      True T.
      My blog
      Quote Originally Posted by Mike the Optimist
      You know with your facilities, I'm sure we can. All we need is a willing victim (err... customer).
      We'd have to get 4 tubes across the bottom of the engine, and keep those tube lengths less than 40" I'd guess.
      jp
      ​John Parsons
      Mountain View, CA
      jp
      If only I was at that stage in the build John.
      ....another benefit...or so I've read...is that you don't need as much duration in the cam to get good scavenging.
      Just the same...if you guys show up with an LS and a bunch of tube you are more than welcome to use my Camaro as template.
      True T.
      My blog
      Boston MA
      I believe the ASA cars ran 180 degree crossover headers. Howe builds headers and built the ASA chassis. amybe give them a call. For the life of me I can't see how they're going to work in a street car butthe do sound good.
      1967 #s RS
