    Results 1 to 20 of 33
      Clovis, Ca
      Little Progress on 73 RS
      Thought I would post the progress on my 73 RS
      I just finished painting the car about 3 weeks ago. It is painted BMW Titanium Silver with Black stripes. It was a factory silver car with black interior so I thought I would keep it close to original.
      Just finished the motor & trans and got it installed today.
      Specs on the motor are:
      350 + .030 4-bolt block
      GM Steel Crank
      Wiseco pistons w/anti friction coated skirts, thermal coated domes & tapered pins
      Scat H beam rods
      Balanced @ 1811g bob weight
      Edelbrock Perf RPM heads w/ 7/16 studs
      Crane Variable ratio gold rockers
      Perf RPM Int.
      Comp XE262H cam
      Plan on C5 front, LS1 rear brakes
      175# 2” drop rear springs
      650# front springs w/ AFCO adjusters
      Bilstien shocks
      I will leave the factory F41 suspension F & R sway bars
      If all goes well I should make the Green flag track day at Buttonwillow in November.
      Aug 2006
      That is looking good, keep us updated with more pics, really want to see this bad boy when it's done..
      Aug 2006
      Hampton Roads, VA
      Nice job, keep us posted with the updates!
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      i love thoughs cars
      Northern Indiana
      I miss my '73. Love the silver/black scheme.
      "Champagne taste on a beer pocket book."
      May 2006
      Northern NJ
      Do you have any other pictures?
      1974 Pontiac Firebird Formula
      1971 Pontiac Firebird Formula Clone
      1973 Chevrolet Camaro
      Clovis, Ca
      I have a lot of pictures but they were taken during the bodywork/paint stage. I have not rolled the car out to take pictures yet. If all goes well I should have the front clip installed next week, I will get more pics then
      Metro Detroit
      A little progress. It's already been painted. You are down to install only.
      Piece of cake. I like the colors. Keep up the good work.
      R.P.
      Vail, Arizona
      Yea! Looks great! I love the 70-73 Camaros.
      Keep up the good work. I love the silver and black too.
      Aug 2006
      Easton, PA
      looks good, nice to see the factory AC (considering most guys ripped them out over the years). I should be posting shots of my brother's '70 RS up here soon.
      GRAND HAVEN, MICHIGAN
      Looks Good.
      1970 1/2 RS Z28...
      Clovis, CA (again)
      hey...where are all the pix you've been taking?
      Dave H.
      Aug 2005
      Hamilton, NJ
      Woo-hoo!
      Scott from NJ.
      Vent Windows Forever! ...
      Michigan
      Man 'o man.... I want a '70-'73 Camaro. You absolutely NEED to post you'r pics ASAP!!
      Clovis, Ca
      Well, here is another pic of the underside of the car. The thing is you can spend a ton of hours doing the grunt work (cleaning off 30+ years of grime) and it does not look like you are making much progress.
      I got the under side cleaned up and painted, rear susp. and rear end pulled and exhaust hung. I also got the motor wiring all finalized.
      I put a flowmaster exh system on the car, and I have to admit they have a well fitting system. I have come to expect that "kits" don't really fit, they are a short cut for complete custom fabrication. This kit or system FIT. With a little cutting and welding it went in perfect, I would recommend it if you like the flowmaster sound.
      Not too exciting but here you go.
      And Dave H., don't for get to bring the roller next week so we can get the dynamat installed.
      DaveG.
      May 2006
      Northern NJ
      Get a little carried away on the paint?? lol The top of the jackstands are painted to match the car. ;)
      Clovis, Ca
      Finally got some more part in and thought I would post some more pics.
      Got the front C5 and rear LS1 brakes installed
      GW Del-A-Lum LCA bushing and BJs installed
      Just got the Pole position UCAs in and installed the springs and shocks.
      Got the tires mounted on the Billet Specialites Qualifer wheels
      Waiting on a couple more part, then should be hanging sheet metal
      Byfield, MA
      Nice Car, I love the color as well.
      What master cylinder are you planning on using with the C5/LS1 brake combo? Also, if you don't mind me asking, how much is the brake setup running you so far? I'd love to do that to my 71 as well.
      Thanks!
      Feb 2006
      Columbus, GA
      Dave, Very NICE! How expensive was it to go to the C5/LS1 brake combo? Excellent color combo, too!
      1970 SS Camaro, 502 RamJet, TKO600 Tremec, 3.91 Moser 12 bolt/Detroit Tru-Trac, C5/Z06 Brakes.
      Clovis, Ca
      It does not take a ton on money to install the C5/LS1 set up if you search around for some deals.
      On the rears I am not sure exactly how much I have invested because I had a lot of the part for some time now and can’t remember what I paid for them. To do it right, you will need 2 left backing plates and 2 left calipers. I use the factory parking brake cables and modify them to work. If you bought the parts through GM parts direct you might have $500 less rotors in all new parts. If you searched on ebay for deals on calipers you could do it for less.
      On the fronts, I machined a 3rd gen Camaro rotor into a hub, used a set of low mileage calipers from a C5, local auto parts rotors, brackets and hoses from Kore3. Even with new calipers you should be able to do the set up for $500 with a little work and fabrication.
      It’s all the little stuff that costs, like replacing ball joints, bushings, bearing, seals, and all the other stuff you see worn out when you have the thing apart.
