      Jan 2002
      Italy
      Corvette C4 angle?
      Is it right to suppose that the halfshafts on my Dana44 c4 corvette rear are to point straight out (seen from above), or should I point them a some degrees rearward rearward to be sure to always have an angle at the u-joints?
      thanks!
      Have Fun!
      André
      2009 Chrysler 300C Touring.
      3.0 liter V6 diesel, five speed auto, black with light grey leather.
      1968 Chevelle Coupe.
      355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
      1980 Chevy Van (shortie G10).
      355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
      2000 BMW 540i Wagon. (FOR SALE €7K)
      4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
      2001 Ford Focus Wagon.
      1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
      1968 Benelli Motorella
      foldable 50c scooter to go in a car trunk.
      2x '90s Yamaha TZR 2stroke bikes.
      one 125cc one cylinder and one will be 350cc two cylinder.
      May 2002
      Northern California
      Hi Andre,
      how ya been?
      I had 2 up on the 4 post rack for inspection for the same reason. It seems factory had a slight angle rearward (3-7 degree). Most likely for u joint life and NVH. Are your half shafts stock or narrowed?
      MrQuick ΜΟΛ'ΩΝ ΛΑΒ'Ε
      Jan 2002
      Italy
      Hey man, its been a while
      Its an 85 rear and its not narrowed.
      To me it looks like hub is to be 1 3/4" rearward compared to the center section.
      I havent measured any degrees though.
      Have Fun!
      André
      Fort Worth, TX
      Is it built-in??
      Quote Originally Posted by Tigergutt
      thanks!
      Andre/MrQuick,
      I'll be out in the shop to check this, but doesn't the lower link that goes between the diff and the hub assembly set that angle for you?
      thx,
      -jeff d
      Jan 2002
      Italy
      Thanks Jeff,
      Unfortunately it doesnt as you are able to move the hub several inches if its not set to the car.
      I appreciate your effort!
      Have Fun!
      André
      Fort Worth, TX
      Maybe I'm missing something...
      Just a follow-up..........
      Set up the suspension on my chassis table, and there is indeed a ~3 degree sweep rearwards on the suspension. The lower control arm that goes out from the diff to the hub locates things pretty solidly. I didn't notice any movement/deflection fore/aft. Comparing all my other measurements that I took from a stock C4, I'm pretty sure that I got everything assembled properly.
      Like I said, maybe I'm missing something, but it looks like there is a little rearward sweep to the halfshafts. That intentional misalignment coupled with the slight (~2 degree) "droop" in the halfshafts is all probably there intentionally to keep the u-joints happy.
      -jeff "reverse engineering is fun!" d
      Jan 2002
      Italy
      Cool Jeff, thank you!
      I appreciate it
      Have Fun!
      André
