Thread: TCI Super Street Fighter
09-27-2006 #1
Buddy of mine has a 68 440 GTX with low 3's or high 2's in rear. 2800 stahl. Tranny burnt up. 1/2'' of metal shavings in pan.
Mechanic said the stalh was to much for car with that gear set. My question is, could this happen to mine?
355 gears
25.71'' tall tires
TCI 3800 stahl recommended by them
TCI Super Street Fighter recommended again.
454 with 550hp.
I really do not want to burn this tranny up. It is FANTASTIC right now. Shifts hard, no lag and lanches the car GREAT.
Thanks for your comments in advance
69 RS Rat. Ocean View, De. 19970 If you wake up and you can put your feet on the floor, IT'S A GOOD DAY!!!
10-03-2006 #2No transmission guru's on here with an opinion?
10-04-2006 #3
- Nov 2004
- San Antonio, Texas
- 218
your stall should not be higher than your cruising rpm..if your pulling 2500 at 70 mph then your converter is not fully locked..your trans will over heat and eventualy burn up...have seen this happen before at my shop
