    Results 1 to 16 of 16
    Thread: Opinions Wanted
      Springfield, Mo.
      Opinions Wanted
      I am installing a C5 brake kit on my 67 and found a killer deal on a set of corvette calipers...
      Since i have to keep my budget in good shape I bought the calipers but of coarse they have "CORVETTE" written on them...
      Would it be tacky to leave "corvette" on them since they are going on a Camaro? I am a little worried about grinding the lettering off because I fear that i wont be able to smooth them down to a perfectly smooth surface
      if i should smooth it down how can i do it without leaving marks from the grinder / dremel ?
      1967 Camaro - Done!
      1968 Camaro - Underway
      CHICAGO SUBURBS
      Anything aluminum is pretty easy. Just stop grinding when there is only a litle raised area left and finish it with 36 or 80 grit sandpaper foloved by finer and finer paper until you get your desired result. To try to keep the as cast look is harder. You could just sand them up and get them powdercoated or maybe try that caliper paint I've seen out there. FRANK
      Boston, MA
      Do the finishing work with a 3" air grinder with the spin-off disks. You can work down to a fine grit then using a high heat epoxy you won't see any of the scuff marks.
      ~Ryan
      Springfield, Mo.
      Thanks guys, I havent dealt too much with alum so i wasnt sure.
      1967 Camaro - Done!
      Dunwoody, GA
      I wouldn't show off the lettering. So either paint over it or sand it down. It want be that hard to sand it down like mentioned.
      Trey
      ~ Jon Hammond
      Tacky is in! Pimp your ride! Leave the Corvette on the calipers. I like the Corvette on the Calipers.
      Mike
      www.musclecardeals.com
      Coronado, CA
      If I had Viper callipers on my mopar I would leave "Viper". Those kind of calipers are almost a brand of thier own. They would show the general public what you got and at least a hint to the mods you've put into it.
      Johnny C.
      Aug 2006
      Hampton Roads, VA
      It's up to you--no one seems to have a problem with the LS-6 "CORVETTE" valve covers, no matter what chassis the engine is installed in.
      Personally, though, I like the idea of grinding them down and either polishing or painting the calipers and leave people guessing!!
      Paul
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      Apr 2002
      North Central Texas
      Quote Originally Posted by HILROD
      Just stop grinding when there is only a litle raised area left and finish it with 36 or 80 grit sandpaper foloved by finer and finer paper until you get your desired result. FRANK
      I did this to my C5 calipers but in between the grinding and the sanding I flat filed them. Flat filing is easy and you can get a nice uniform surface. If you use this method, be sure and clean your file often, especially on cast aluminum. Good luck.
      Shannon
      Modo Innovations
      940-391-9002
      Aug 2005
      Hamilton, NJ
      Quote Originally Posted by Bandit
      I do - that would irritate me in anything other than a vette.
      Grind 'em!
      Scott from NJ.
      Vent Windows Forever! ...
      Dunwoody, GA
      use WD40 to keep aluminum from sticking to a file or drill bits or high speed cutters. We do this for machining aluminum on lathes and mills. Works great even on somethign simple like drilling a hole.
      Trey
      ~ Jon Hammond
      Nov 2002
      Georgetown,TX
      I can remember when adding Corvette components to our rides was the cool thing. Now,it's not?
      Dang,I feel old.
      Oct 2005
      I left Corvette on mine, heck I even got the pimped out red "Z06" calipers. I actually get lots of compliments. I'm with USAZR1, I thought updating with corvette parts used to be the way the factory "supported" hot rodding of Chebbies.
      James Greenwell
      1991 Z28 "TrakCar"
      LS2/ T56 430 hp/ 435 tq
      Never Done/ Money pit
      1972 Buick Skylark "Benchwarmer"
      455 stage 1, 700r4
      1989 Trans Am TTA #657
      3.8l V6 Turbo cruiser
      Macon, Ga.
      Quote Originally Posted by vintageracer
      Thanks for that Mike, glad I fit in with the malibu.
      Bill
      Trailers are for BOATS!
      Yo Hommie Billy, you be lookin gooood with dem red binders!
      Mike
      Macon, Ga.
      WORD!
      Bill
