      new york city
      Car Chemistry Collector Inserts
      Has anyone used or does anyone have any firsthand knowledge of the car chemistry collector inserts. I have the spintech 3" side exit on my car and it is a liitle to loud for regular street driving. I was hoping to quiet it down a little bit without removing the side exhaust. Any ideas?
      I was also thinking of putting some dynomax bullets on the inlet side of the mufflers. I heard you can use them as resonators after the mufflers, but with the side exit I can not fit them there.
      http://www.carchemistry.com
      Loganville, GA
      Tmat, I made up an insert like the car chemistry ones for a Quad 4 car I had. It did help a little bit, not a lot though. You can put the dynomax mufflers ahead of the spintech's. Many a factory car have the resonators first then the mufflers after. Good luck.
      2018 Cruze LT Hatchback
      2003 Suburban 2500 8.1L
      1975 MGB Roadster
      2003 GSX750F Katana
      Aug 2001
      Wilton, CA. (Sacramento)
      Quote Originally Posted by TMat
      They do quiet the car, but are quite restrictive if it's a high power car.
      Jody
