Thread: AVATOR HELP.....need resizing
08-16-2004 #1
Can someone resize this for me so that it can fit as my avator, i havnt installed photo shop since my last re-format
Thanks,
David:3gears: 68 Rally Sport Camaro 350/4spd(t56ingarage)/8.5 10bolt 2.56 open,Hotchkis springs, kyb shocks, 17" Rallys 235/245-45-17
1989 Pontiac Turbo Trans Am 3.8 Buick LC2 V-6 w/51k, Ported heads w/oversized one piece valves, te-44 turbo,PTS built 200R4 w/2800stall, Lucas green top 009 42.5# injectors, AFPR, Adjustable wastegate, ATR 3inch exhaust, Terry houston 3inch mandrel bent downpipe, stock intercooler w/duttwieler neck, Eibach Springs, Bilstien shocks, Spohn adjustable panhard bar...
08-16-2004 #2
Here you go, it's 80X40. It says your avatar should be no bigger than 80X80.
Note: It looks like you can size it yourself when you edit your avatar. Go to Edit Options> bottom of page to Miscellaneous Options> select Enhanced Interface. Now when you place the avatar you can size it, although it does not tell you the pixel count that I could see.
08-16-2004 #3
sweet, love the bird by the way, ive seen ur sight before and man is that thing clean...
08-16-2004 #4
np David, thx for the props.
