    Results 1 to 12 of 12
    Thread: GM Steel Crank
      GM Steel Crank
      I am going to tubo charge a 355 sbc. I have a standard steel GM crank will it hold up to 1000 HP?
      mo
      No,You really need to consider a forged crank,has as eagle,or callies,I have seen guys turbo a stock crank,but in my opinion it's just waiting to break.
      Nov 2004
      Colorado
      I think he said its a steel crank. That would mean its forged. I'd run that stock crank long before I stuck a POS chinese eagle crank in there.
      The Callies dragonslayer is a US made 4340 non twist forging. That would hold up. They do have problems breaking the snout off in supercharged apps, so you might want to consider getting the BBC snout on it.
      mo
      I use Eagle and Callies cranks,And have never had problem with a Eagle crank.
      Aug 2006
      Hampton Roads, VA
      scat
      1980 Pontiac Trans Am, Chevy Big Block 468, TKO 600 Trans, Hotchkis TVS, Bilsteins, Eaton/Motive 3:73's, 18" Coddington Junkyard Dogs, Nitto NT555 rubber, Autometers http://www.fquick.com/Bandit
      http://www.cardomain.com/ride/2458763
      mo
      They bad thing about a GM steel crank,they aren't not 4340 they are weak steel crank,A gm cast crank is steel.
      As a engine builder my exp with Scat have not been good ,we have broken more scat parts,than any other.I advice is not to use a Scat.
      Aug 2006
      Hampton Roads, VA
      Quote Originally Posted by rocketman
      OK so for a bulletproof forged crank then, what do you suggest?
      mo
      Well if price is not a concern Callies,If not Eagle.
      Southern Indiana
      as for cranks,,,
      actually stock cast cranks are cast iron in designation but have elevated carbon levels making them a ******* yet I do know my old boss had a stock GM steel 1051 crank in his drag car with twin turbos. and it lived till the block (stock GM) gave away.
      But as for cranks I have built many engines with Eagle, Scat, Callies, Crower, etc.
      My present 3 customer engines going together are using Eagle ,Callies and Crower.After breaking 4 scat cranks ew figured they work for lower power engines but not big power.
      As for Scat and Eagle, the Eagle cranks are made in an old forging factory that used to make titanium forgings for Mig knock offs and Eagle set the bar so high for its tollerances that the worst crank is so far above the specs its unbelieveable.
      While some people keep saying buy American ,when presented with choices some people just cant afford some higher end domestic stuff.
      It seems that when parts go global in production most people forget we have been using a lot of taiwan/mexican/chinese parts for years and never complained till it rusted or chrome peeled.
      When presented with good products made cheap we buy, and we have to face it.Well some dont and some just pop out the "Buy American" slogan. But when it comes to dollars down buying ,we just buy what we have to.
      The only problem with buying outside America is that the other compnay doesnt compete as fairly nor do they buy tha same amount as we do.
      Oh and the next time you have someone toss out the American label go check and see if they have a set of overseas made Goodyear tires.
      Anyway , you can use a properly preped GM steel crank and it will live for a time with proper harmonic dampening, I would use ATI super damper and get it balanced properly and for a rod i would recomend Oliver. you cant go wrong with them. And they are about as bullet proof as you can get for rods. We have only trashed rods on journals that broke on every engine that failed for what ever reason.
      Proper timing control and fuel mangment is the key.
      But for reliability/longevity you should jump up to a better crank. Its like this re you going to use stock cast flat tops to make said 1000hp, no well build it to live at 1350 hp and it will never break.
      My engine building theme is to build it so the max output would be around 80 to 85 percent of the "rated " capacity for the longblock to withstand.
      Good Luck
      Lee Abel
      AFTERMARKET PERFORMANCE
      Oct 2005
      Ferndale, WA
      Billet Crank?
      72 Chevelle Done!
      67' Hell Camino- Under the knife
      Some day: Porsche GT3/ C6R inspired 69
      Oct 2006
      Ottawa, Ontario, Canada
      I think i'd be worried about the mains walking around in a stock block before the stock crank gives out....
      Especially a steel GM crank if prepped well will outlive the block by far.
      1000HP is not THAT difficult to make with the right turbo on 355 cubic inches.....think about what you want, 1000HP vs longevity
      -Carm
      '69 Firebird Twin Turbo SBC 400" Blow-through
      9.80 @ 141 w/ 1.88 60-ft..... on 17's
      9.21 @ 153 w/ 1.45 60-ft..... on PUMP GAS
      8.60 @ 164 w/ 1.46 60-ft..... on RACE GAS
      Oct 2006
      BTW i use the Eagle rods w/ L19 rod bolt upgrade & many others as well. They'll pretty much take anything you can throw at them, and are in many 8 & a few 7 second cars. Eagle themselves rate them @ 1200HP +
      They will survive, but are heavy, so keep the piston speed down (more stroke) and you'll be alright.
      -Carm
