Results 1 to 20 of 25
Thread: PCV inside a AN hose or fitting?
08-29-2006 #1
Hi,
from my one valvecover to the intake manifold I'll run a PCV valve but I'd like to hide it inside an AN hose or fitting to avoid using the ugly rubber grommet, have any of you tried this??
are there different sized PCV valves around?
thanks!Have Fun!
André
2009 Chrysler 300C Touring.
3.0 liter V6 diesel, five speed auto, black with light grey leather.
1968 Chevelle Coupe.
355cid, Viper T56, Corvette C4 IRS (Dana 44) and Corvette C4 IFS with Porsche 6piston Brembo's.
1980 Chevy Van (shortie G10).
355cid, TH350, 8.5" 10bolt posi and Belltech spindles.
2000 BMW 540i Wagon. (FOR SALE €7K)
4.4 liter V8, six speed manual, lowered and with Bilstein B8's, silver with black leather.
2001 Ford Focus Wagon.
1.8 liter turbo diesel, and a whoppin 90HP.:bsjerk:
1968 Benelli Motorella
foldable 50c scooter to go in a car trunk.
2x '90s Yamaha TZR 2stroke bikes.
one 125cc one cylinder and one will be 350cc two cylinder.
08-29-2006 #2
Use a crankvent, its a fancy bilet aluminum PCV valve.
They have a AN connection version but its not shown on thier webpage
http://www.et-performance.com/turbo.html
Free hostings of solid models!
http://www.wrenchmonkey.com/Webpages/Solids/Solids.html
92 Stealth Twin Turbo with 3.5L Engine swap
Looking for my next project, maybe an AWD 71 Lemans????
08-30-2006 #3
thanks, looks like what I need, but at a whoppin $110!!!!!
I might end up getting it if I cant find anything cheaper but other ideas are welcome.Have Fun!
André
08-30-2006 #4
EDIT: A PVC valve is NOT the same as a check valve, soory for the bad idea:(
Isn't a PCV valve just a ball check valve? search mcmaster Carr
http://www.mcmaster.com/Free hostings of solid models!
08-31-2006 #5
thanks, I'll look into that
Have Fun!
André
09-01-2006 #6The crankvent sellers claim that the crack pressure and opening speed is critical, I have no clue
09-02-2006 #7wow, that I dont know..... but a ball valve should be pretty fast as well...
but I know that without any valve in case of an engine backfire it might ingnite the crankcase gases and blow the thing apart.....
Have Fun!
André
09-05-2006 #8Ordrered a 3/8"npt stainless ball check valve from Mcmaster today, thanks for helpin!
Have Fun!
André
09-07-2006 #9
- Jul 2006
- Chesapeake, VA
- 678
I don't think you want to do that. Please see here: http://www.jalopyjournal.com/forum/s...ad.php?t=61376 it explains the PCV system thoroughly complete with a cutaway PCV valve and an explanation of how it works.
09-08-2006 #10Thanks for replying, I read the article (very nice) and didnt find the reason to not use a ball check valve.
is is due to the different flowing rate of the pcv at different vacum?
thanks!Have Fun!
André
09-08-2006 #11
- Jul 2006
- Chesapeake, VA
- 678
Yes. I believe your engine will see a massive vacuum leak at idle. The PCV actually flows LESS under high vacuum (idle) and MORE under low vacuum (wot or heavy load) because the shuttle inside the valve is pulled farther into the orifice with increasing vacuum.
09-12-2006 #12considering that you are probably right.
Since I already have it I'll give it a try anyway and see if it causes a major vacum leak.
Have Fun!
André
09-12-2006 #13Sorry about the bad information, thanks for the good link on PVC valves!
I felt so bad for leading you astray that I went to the autoparts store and they let me look through thier selection of PVC valves.
Purolator PV1020 looks like 2 barbed hose ends butted together. One end is made for a 1/2" diameter hose and the other end is made for a 3/8" diameter hose. The biggest part of the body is .594" in diameter.
You might be able to slipit completely inside a #10 AN hose.
If you turned it down on a lathe or even just filed it down in the center it would definitely fit completely inside a #8 AN hoseFree hostings of solid models!
09-12-2006 #14
